Milkshake Oil - Extreme short trips
So, I just found this thread and as is typical of me, i’m late to the dance (story of my life…..)
Anyway,
First, the oil capacity for a 98 Corolla with factory filter is 3.9 quarts. An oversized filter will cost you an additional couple of ounces bringing you to 4qts total. How you were able to get 4 1/2 qts , top dot of dipstick, is beyond me.
My Corolla habitually is short tripped as shown by its low total mileage. That being said, in all the years of me changing the oil, it never came out like that. Sorry to say you have other things going on in that 1ZZFE.
When you start the engine, do you notice if you see the coolant in the reservoir bubbling?
If it is due for a spark plug change soon, then I'd do a leak down test while changing them.
Otherwise, I'd wait and not do a used oil analysis just yet, since it isn't driven long each time. Instead check this most recent oil change, daily after driving, then in a couple days, then 4 days, 8 days, and so on, extending the amount of time till the next check, except if it is taken on a longer trip that warms up the engine, then check right after that too. I mean educate her about the importance of checking it herself on this extending interval and then it is up to her to do it, or not... maybe a little reminder every now and then if she is forgetful.
If the vehicle isn't in terrible condition, then it could easily be worth DIY replacing the head gasket, but go ahead and replace the PCV valve now if it hasn't been done in a long time which it probably hasn't.
Telling her to walk for her health, it may not be as unreasonable in Seattle as it is in some areas where you don't really want the elderly walking in extreme heat or freezing weather that poses an ice-slippage risk. It is easy for younger people to assume that everyone is in perfect health as they get older but eventually that is no longer true and walking more doesn't necessarily fix that. YMMV. If she wants to drive then she ought to be able to if it is reasonably sustainable to keep a vehicle running.
There is 'short tripped' and there is short tripped. This is the latter. One quarter of a mile per journey with cool-down in between is not just 'short tripping' it is very severe service. The engine will spend ALL of it's time in cold fuelling mode, meaning a lot of fuel dilution. The water from combustion will accumulate with no opportunity for evaporation. The engine will be in warm-up conditions constantly and the oil will never get warm enough to work properly. You may as well hose water and fuel directly into the oil charge. OP reports that the coolant level is fine and clear.
Of course there could be a coolant issue too, that the short-tripping is masking or antagonising so maybe worth a used oil analysis check for glycol, but I can see this just being the very worst case of condensation and fuel dilution possible.
Maybe a good sign. I would keep an eye on the oil condition and maybe change it again soon.
I am curious on how long the oil change interval was for it to look that bad.
looks like every forklift that comes to me for service. short trips and minimal runtime will do that. id change the oil , go for a burn on the highway providing the coolant level is good and just send it on down the road.
recommend a shorter interval to her would be the cure imo
That doesn't surprise me. Propane produces a lot of water when burned. It seems like I recall a figure of around 4 liters per 100k of BTU's?
I disagree that this milkyness wasn't caused by short tripping. I saw this in a Mercury Villager I owned a couple decades ago. Lots of short tripping in cold weather. The oil definitely had moisture whipped into a milky looking concoction. I posted a picture probably 20 years ago, but can't find it now. That was the first and last time I saw that much moisture in the oil.
Drain pan looks like it had 6-7 quarts in it.
C3H8 + 5O2 --> 3CO2 + 4H2O.
So burning 1 mol of propane yields 4 mols of water (plus 3 mols of carbon dioxide).
Burn 44g of propane and get 72g of water; so you get around 1.6x as much water compared to the propane burnt. That assumes complete combustion under ideal conditions.
So yes, a lot of water. It's similar for any hydrocarbon.
my customer has more gas powered forklifts then propane for ease of refueling but nevertheless. it is a ongoing problem for that particular fleet. only the big diesel hyster is exempt from moisture in the oil as they leave it running for hours on end
I do similar driving....very short drive to work.....
My oil never looks like this.......
Looks like a head gasket or ceratec.....
why dont u just go on foot? It does not make any sense using the car for this extremely short distances
Extreme short-tripping is considered "severe service". I would chose a cheap Full Synthetic or syn blend high mileage oil and change the oil every 6 months or 3000 miles. SuperTech Full Synthetic HM or Maxlife syn blend and Super Tech filter would by my suggestion.
-20c most of the year - - - - then we shoot to +30c
plus I have 2 little kids that come to work with me - - -
I am a teacher >:)
I'm still not seeing the need for a car. Good clothing, decent footwear and some sunscreen maybe.
That's not from short tripping, you have a bad headgasket.
This was the correct, or correct enough, answer to the original post, Dishdude called it in seconds, but that didn’t stop calls for used oil analysis. Look at the drain pan picture and describe what information would come from a used oil analysis? Also in the mix was serious entertainment of this being caused by short tripping. I don’t think that mileage was mentioned, but the situation is clear: massive coolant intrusion into oil in a 26 year old economy car. Better maintenance might have have prevented this. I love the idea of saving an old car, but it’s hard to make any economical sense of a head gasket change, engine swap, etc. Change the oil and keep driving, but it’s the end of the line, despite this discussion.
Hahahahaha - - - -
Gotta love internet judgement.
People like you crack me up.
Thanks Weasley, for the unsolicited pearls of your wisdom.
Back to reality.......
