Originally Posted By: Olas
If it lists 502 or A3/B4 it's good enough, if it only lists API it's not good enough. If it lists both, refer to first point.
It really depends what you're trying to do. ACEA specifications tended to come when the API was getting slack. Another major contributing factor, however, was European manufacturers expecting way too much from an ordinary API conventional. A 12,500 km severe service interval on SJ conventional on my old Audi 200 Turbo was simply a bit too optimistic.
The oil specification certainly was weak. But, when Audi chooses to go significantly longer on an oil change interval (longer on the severe service interval than many other manufacturers went on regular service) and with a turbo, no less, there's no surprise things didn't work out. "Weak" specifications are just fine, provided one uses the products as intended.
