Originally Posted By: CapriRacer
So reading all this, I think the problem is not the tires but something else.
First, tire vibrations would be there all the time at certain speeds. It would not be intermittent, but it would be speed related. Get to that certain speed and it should show up every time. Accelerating, or coasting should make no difference.
Also, it is EXTREMELY unlikely that ALL the tires have the same problem. What is MOST likely is that ONE tire would be a problem - and not only would RoadForcing the assembly isolate it, swapping the tires around the vehicle should reveal which one it is as well.
So I don't think your vibration has to do with tires. But we will see when you replace them. If the vibration remains, then the problem is something else.
What else would it be?
Originally Posted By: mrsilv04
I don't see how that much (or little) inside wear, after that many miles, is such a huge issue.
That's less wear than on the inside of my tires, after 45,000 miles, and mine was aligned after the front end was worked on.
Yeah, I'm more inclined to think that inside wear is more the result of aggressive cornering than an alignment problem. Couple of reasons I say that - number one, it's never pulled, number two, I like taking curves, and the truck has always had great steering
