Michigan had a real bad winter this year and I was real impressed with the cross terrains on my 2wd 98 F150. As bad as the winter was this is the first time I ever felt safe driving 2wd PU through all the snow & muck. My wife felt the same, if weather was bad she wouldn't go out unless we took that F150.
I need tires for newer truck and can't find the Michelin CT's...did the Michelin LTX M/S 2 replace the CT ?
What other tire should I checkout that has same or better performance than the Michelin CT ? P235/70R16
Thanks
Thanks
