OVERKILL
$100 Site Donor 2021
"Back in the day" a good friend of mine had a cabin cruiser with a 4.3L, think it was at least 25', similar to this one:Ummmm ... very good point about the slip but would disagree to suggest or maybe imply a marine engine has the same load as a vehicle with wheels if I am understanding your post. But I think you maybe suggesting physical bogging down of the engine by improper propeller, vs the high load of pushing a barge (boat) through water. MeCruiser does note the tremendous load marine engines are under.
Oil temps will run far hotter, also taking into account the high RPMs and huge gas consumption compared to a car..
Also the 2,000 lb weight you mention is too light, A 21ft Chaparral from the factory with this engine weighs in at 3,100 lbs dry weight.
Throw in a full tank of gas 240 lbs, plus the boat has a passenger capacity of 1,600 lbs. You can be pushing close to 5000 lbs.
These engines are also used in twin configurations for boats weighing twice the dry weight mentioned above.
$10,000 25 ft Bayliner Capri Custom Cabin Cruiser Menlo Park
The "Orca One" is a modern 1992, well maintained,
www.allboatlistings.com
And it's gotta be at least 5,000lbs.
