Good morning everyone. This is my first post here but nowhere near my first time here. Been lurking a long time and finally had enough of a reason to sign up. Me? I'm an engineer with experience in labs in chemical industry. Currently a QC guy/operator for a plant. My engineering background is in chemical/petro chemical.
To keep a long story short, this is technically the third iteration of this engine in this boat. I repowered May of last year with what I thought was a good low hour used rebuild. That died of water ingestion due to neglect of the previous guy. (I should've known better) To quote my machinist... "the bores were as rough as the surface of the moon. How this thing made no noise and didn't come flying apart I will never know. It was a fresh rebuild at some point... I guess." Post rebuild it is a vortec roller engine circa 2003 with new internals. I had a problem last year of seeing moisture in the manifolds which has been corrected by installing the correct cooling system configuration for my M.Y. So it is now the third iteration. The water seen was condensation formation best we could tell.
Anyway, I occasionally see some light vapor from the breathers which seems to be normal. I don't get any condensation on the valve covers or oil fill cap. I've attached the UOA for the first two changes below. Some things to note, I can only do an oil change by extraction pump, I have no pan drain due to the dip stick configuration. The extraction pump was new, and could potentially be the reason for the higher silicon levels? Delvac 1300 15w-40 flavor of choice.
First oil change 11 hours:
Note the thinning in the short time...
Second change at 37 hours (48 total):
Some things to note on the second interval. I added a remote oil filter mount in the middle of the interval. Uses a standard pf454 style filter. I replaced the filter bypass spring in the boss in the block. There was a quart of 25w40 quicksilver make up added to it during this interval as well as a splash of delvac... it is what I had laying around. Again with the thinning.
I don't think wear is out of line here being still near a fresh rebuild. I do think my engine doesn't like delvac 1300. My machinist recommended it, I have a ton on hand as I run it in the 33 with the twin diesels but am open to other suggestions. The silicon and sodium stand out to me. Could be from the new extraction pump I suppose or something else lurking. I have pressure tested the block and my machinist tore it down when I found the water and checked it again. Everything seems kosher so we left good enough alone.
Any further insight or interpretation is appreciated.
-Paul
-Paul
