I recently had my transmission fluid flushed. While my owners manual calls for DexIIIMercon, as we all know, it has since been replaced by Mercon V. I had my transmission fluid flushed at a local shop however and went with the same old Formula Shell Dex III Mercon + Lubegard Red that i've been using with success for the last 2 transmission flushes. The car now has 85,000 miles on it and i've been keeping it flushed at around 25-30K mile intervals.
Prior to making this decision i did some reading on the various fluids and was wondering why, since Mercon V is newer and part-synthetic, it is also higher viscosity (thicker) at operating temperature, has a lower flash point and almost the same pour point as the old DexIIIMercon? I'm not seeing the benefits for upgrading to the new Mercon V.
Am i missing something?
FWIW, my old fluid, with 30,000 miles on it, was still bright red, didn't smell burnt, and in doing the blotter test, looked fine. The car sees a lot of short trips mixed with long stretches of highway use. It runs around 3000 RPM at 72 mph.
