Title kinda says it all. Accidentally did a full transmissionmission fluid exchange with Motorcraft mercon LV instead of V. Didn’t read the bottles till afterwards, so it’s full of around 18 quarts of the stuff. Truck has around 250k on it, not sure if the transmission has been replaced (it has to, I don’t think many of them make it 250k without transmission work). Pan had some very fine metal in the magnet but no clutch material in the pan at all. I have no idea what fluid was in it, other than it wasn’t burnt and still had some red to it. Truck has been driven about 10 miles, shifts just as good if not better than it did before. I’ve gotten mixed responses, people saying get it out now and hope you didn’t burn it up, to people saying they used it in a unit behind a 7.3 turned up to 500hp and haven’t had any issues. The hive mind seems to like the Maxlife Universal, which is also rated for V AND LV applications and has a very similar viscosity at 100C, 5.9 Cst vs 6.0 for the motorcraft. So I don’t know if I should just drive it and not worry about it, or bite the bullet and spend another $150 on fluid to change it out again.
