The '05-'07 Foci spec Mercon V for automatic transmission fluid. However, the same engine/transmission combo in the '08-'11 Foci specs Mercon LV fluid. The LV stands for 'low viscosity' IIRC, and as put in place to net some MPG gains I think. Any reason I couldn't run this fluid in my Focus? The transmission is the exact same as the '08-'11s had. Right now I'm actually using MaxLife ATF which claims to meet/exceed both Mercon V and LV. Supposedly, Mercon LV expands more when hot.
