Mercedes ATF - Shell 134 or something else?
Los Angeles, CA
Hey all,
Getting ready to do a drain and fill on our ML 350, last time I used Shell ATF 134. Any thoughts on that? Would there be a better fluid choice? I was considering using Valvoline Maxlife ATF as it has been praised so well.
Thanks -
Anthony
Shell ATF134 is probably the most economical (and approved) option if you have a local distributor.
You can get the Shell ATF 134 from a shell distributor.
https://www.shell.us/business-customers/lubricants-for-business/lubricants-distributor-locator.html
Last time I got a case it was in the $60 range for 12 quarts. That was a while ago, not sure about the price now.
Shell is on MB's approved list, but Valvoline Maxlife ATF is not. It's just recommended by Valvoline. Valvoline does have an approved fluid on the list, but I've never seen anyone sell it.
https://bevo.mercedes-benz.com/bevolisten/236.14_en.html
Price has gone up, of course...now it’s $50 for 6. Which is still cheaper than the alternative Mercedes options.
Who did you call? Last time it was a little higher than $60 but not almost double. I think 134 FE was around $80 for 12 quarts and 134 was a little bit less than that. That was a few months ago.
That’s the price on Amazon.
Oh, yeah, they're always much higher as shipping costs are high. You have to go to your local distributor. I've called them up and asked. They'll say something like, we got 120 cases in stock, how many do you need? Then I say just one, cash sale. Check the link for your local one.
There's a whole "Sticky" thread on this at the Benzworld forum.
This image is supposedly from a factory repair manual.
You realize that's from 2007 right? I believe 236.14 replaces 236.12. I believe 236.15 and 236.14 are different though so they shouldn't be mixed up. OP didn't mention the year ML but the older models used ATF 134. In the E class they went to ATF 134 FE in the 2011+ time frame so it's possible that it's not the right fluid depending on the year.
Yes, knowing the year of the MB would be important.
I usually work on the w210 series.
Valvoline claims that this fluid works for:
Mercedes Benz MB236.1, MB236.6, MB236.7, MB236.9, MB236.10, MB236.12, MB 236.14, MB 236.15, NAG-1
Yeah but it's not on MB's approval sheets. The 236.14 is a red fluid and 236.15 is a blue fluid. You really think Valvoline made a fluid that works equally great in both applications when MB makes two different fluids?
Shell ATF 134 (MB 236.14 certified) is semi-synthetic, back label. A Valvoline "ATF Pro 236.14" is claimed by manufacturer as "full synthetic".
Does this mean that there IS or there ISN'T a difference between the two? If a spec can be met by a semi-synthetic formulation, why would Valvoline meet it with a "full synthetic" formula? Can one 236.14 certified fluid be tangibly better than the other?
Maybe it's better, it's just that in the US, you hardly ever find that Valvoline on the shelf, I guess it's easier to find in other countries. Here the change interval is every 40-60k miles so while the synthetic might be better, the semi is probably fine if you change it at the specified interval.
View attachment 62564View attachment 62565
shell calls are g2/3 blend a semi-synthetic and valvoline calls it a full?
