So this week I bought a Melling timing kit for my Ford 5.4 3V engine, I got the kit with the cast iron tensioners, guides, chains and crank sprocket. I also got the Melling high volume oil pump since I'm taking off the crank sprocket anyway. The timing kit didn't include the phasers or VCT solenoids but I am not having any problems with those so I was hoping to put those off a few months. It is ticking a bit on startup so I wanted to take care of the tensioners and figured I'd switch out the guides and chains at the same time, as well as the crank sprocket and the oil pump. FYI, you can use the cheese wedge tool to slacken the chain in order to change out the phasers later without taking off the front cover, so that's what I'm thinking to do when I save up some more money.
Now, I'm having 2nd thoughts about the Melling chains and guides. I saw FordTechMakuloco's latest video on YouTube where someone had done an aftermarket timing job using what looked to be the Dorman kit and the guides were chewed up after only 20,000 miles. There seems to be so many dire warnings on his channel and other places on the Internet about only using OEM parts on this engine. Yet, FTM does use the Melling oil pumps on these 5.4 3Vs so what gives? I thought Melling was a quality brand. I also purchased the M360HV oil pump since I am planning on taking the front cover off.
I dunno, but I am having a crisis of confidence on this kit. I am thinking of sending it back and getting the OEM chains and guides, but I still want to use the cast iron tensioners, and the Melling oil pump. I could buy the cast iron tensioners separately without the kit, and use the Ford guides and chains.
I just don't want to have to open the front cover again after 20,000 miles, period. Is this fear of having the Melling kit not last very long rational? It is the Melling "Professional Grade" kit that I got, not the "Service Grade" one. Maybe the folks that have had problems didn't put it on right? I do have appropriate tools like an inch-lbs torque wrench.
