I believe most any diesel oil can be used in gasoline engines, so why would you want it to meet MB 228.51?
Low SAPS or extended drain?
Nice list of oils meeting this spec! Thanks.
Never heard of bunch of them.
Couple of the names from the list that i've heard of are Shell Rotella T6 and Mobil Delvac 1 ESP.
M1 is listed for 100,000 miles! Is that a typo?
From Mobil website:
Mobil Delvac 1™ ESP 5w30
Mobil commercial-vehicle-lube , United States
High Performance Advanced Synthetic Formula Low Ash Diesel Engine Oil
Product Description
Mobil Delvac 1™ ESP 5w30 is an advanced synthetic heavy duty diesel engine oil for long and reliable service. The development of this product summarizes more than 90 years of ExxonMobil's research and development knowledge. The goal was to define a product that addresses all features required with modern on-highway truck applications, including those with emission control systems1. This top performance product offers unsurpassed oxidation stability³ which results in engine cleanliness promoting efficient and smooth engine operation. The robustness of Mobil Delvac 1™ ESP 5w30 meets or exceeds the longest oil drain intervals defined by major global manufacturers, offering protection during extended oil drains up to 100,000 miles¹. It was also developed and tested to protect the engine with the use of biofuel components to consider different diesel fuel qualities and future, sustainability related fuel components. The advanced lubricant formulation helps to gain fuel economy benefits in modern engine applications². The outstanding wear protection performance of Mobil Delvac 1 ESP 5w30 is the result of extensive and close cooperative development work of ExxonMobil with major equipment builders. As a result, this product meets or exceeds the requirements of the latest API and ACEA industry specifications for diesel engine oils, as well as the requirements of many major American, and European engine manufacturers.
¹ Please refer to the owner's handbook for OEM application requirements and oil drain intervals for your vehicle or equipment.
² Compared to an SAE 15w40 engine oil. Actual savings are dependent on vehicle engine type, outside temperature, driving conditions, and your current engine oil viscosity.
³ Based on PC-11 industry test data.
Features and Benefits
Mobil Delvac 1™ ESP 5w30 is an outstanding lubricant solution for modern and latest engine technology equipped with emission After-Treatment devices. It was developed by ExxonMobil to maintain unsurpassed oxidation stability performance to meet long oil drain intervals and support low maintenance efforts. Mobil Delvac 1™ ESP 5w30 keeps at the same time critical and hot engine parts clean, also while bio diesel fuel components are used, for long and efficient engine life. This feature, in combination with the sophisticated additive system, ensures exceptional engine wear performance and supports long engine life. The low ash formulation protects at the same time all exhaust after-treatment parts required to meet emissions regulations.
The key benefits of Mobil Delvac 1™ ESP 5w30 include:
| Features | Advantages and Potential Benefits |
| Unsurpassed thermal and oxidation stability | Prevention of deposits and smooth engine operation |
| Step out wear protection | Reduced engine wear to promote long engine life |
| Bio fuel compatible | Maintains engine cleanliness and protection with bio fuel components |
| Enhanced fuel economy potential | Reduced fuel consumption |
| Extended drain interval capability | Fewer oil changes and less oil disposal |
| Emission system protection | Emissions system durability and performance |
Applications
Recommended by ExxonMobil for use in:
• Most engine generations up to latest and most sophisticated high performance diesel engines with turbo-charger, direct injection and low emission designs, featuring all types of exhaust after-treatment technology
• Heavy duty diesel engines using low sulfur diesel fuels and many biodiesel fuel formulations
• Naturally aspirated and turbo-charged diesel powered equipment
• On-highway short-haul and long-haul trucks and buses
• Off-highway equipment
Specifications and Approvals
| This product meets or exceeds the requirements of: |
| ACEA E6 |
| ACEA E7 |
| ACEA E9 |
| API CK-4 |
| API CJ-4 |
| API CI-4 PLUS |
| API SN |
| API SM |
| JASO DH-2 |
| DAF Extended Drain |
| CATERPILLAR ECF-3 |
