Mazda3 Skyactiv - wrong oil filter?
Massachusetts
Just got the oil changed at a local service place. I was going to do it myself, but time is short and I've got a big trip coming up. I looked at the receipt and noticed they had my 2012 Mazda3 Skyactiv listed as the Sport model, and used a Champ PH2835 filter, which Amazon says isn't compatible. Anyone know if Amazon is wrong, or do I need to go back and have them put a different filter on?
I would go back to the lube place that did the OC and ask tham to show you how they selected the filter. That should satisfy your concerns. If they can't show you why the fiter was selected, be prepared to tell them why it is incorrect. FWIW
Oldtommy
Originally Posted By: cgmazda3
The engine is the 2.0L SKYACTIV G
PH2876 seems to be the correct part.
PH2835 shows for the non skyactiv engine, not sure if it matters but I would have it changed...
That's because "Sport" IS the vehicle's correct sub-model, Not "Skyactiv". Your Mazda 3 Sport happens to have a Skyactiv engine.
Your Mazda 3 Sport is not a hatchback, but a station wagon. Mazda's marketing department worried that some buyers might perceive the word "wagon" as being too repellingly close to their dad's Country Squire with fake wood paneling, so the car got called the "Sport" instead.
According to Champ Labs oil filter application guide there are 2 different oil filters for the 2012 Mazda 3 and Mazda 3 Sport
L4 1998cc engine PH2876
L4 2000cc engine PH2835
It looks like the 1998cc engine is the Skyactiv engine.
Now Purolator has two different filters for your car
2.0L VIN G or VIN F - L10241
2.0L VIN 7 or VIN 8 (Skyactive) - L14612
According to the Champ Labs cross reference:
PH2835 Purolator cross reference is L10241
PH2876 Purolator cross reference is L14612
According to Champion Labs, the PH2876 is the oil filter for the Skyactive engine, so it may appear that they put the wrong oil filter on your car.
Champ oil filter application guide.
http://showmetheparts.com/champlabs/
2876 is right.
The main difference between the PE01 filter and the B6Y1 (and their respective aftermarket equivs) is that the latter has an ADBV, the PE01 does not.
I'm wondering if the G in "Skyactiv G" means VIN G which means use the PH2835?
One of those filters (L10241/PH2835) will not even screw on, as they are 3/4-16 threaded (for the MZR) and the Skyactiv uses typical Metric M20 thread.
I checked out that Champion Labs site and what I found MORE interesting is that there is no fuel filter to replace on the Skyactiv. Apparently, there is a fuel pump/filter module. Hopefully, the filter really is good for life. I suppose it's possible.
Actually, the Sport models don't have the Skyactiv engine - they have the less fuel efficient 2000cc engine. The i Touring and i Grand touring models have the 1998cc Skyactiv engine.
A little off-topic, but the hatchback has nothing to do with the Sport/i Touring designation; there are Sport sedan models too. I think you're right about hatchback sounding more attractive than station wagon though.
Mazda.com says all 3's have Skyactiv engines for all displacements. Wiki says the OP's car does have a Skyactiv engine.
And Mazda does actually call the car a "hatchback", which I was a bit surprised at. Still looks like a wagon to me.
That might be true for the newer year models, but not the 2012s:
KBB 2012 Mazda3 (scroll down to the "Under the Hood" section)
Anyway, I'll take it back tomorrow morning and see if they can get the correct filter. Thanks for the information and links!
Hello, When my sister bought a 2012 Mazda3i Touring with the Skyactiv engine I went alookin' for her filters. The filter had been changed by Mazda. Hastings and Wix didn't have a listing.
Now at least Wix does. 57002 is the Wix oil filter number for the new 1998cc Skyactiv engine.
I'm so happy. Kira
Then the Wiki page appears to be wrong.
Quote:
"2012 update - 2012 Mazda3 i Sport sedan (US)
The 2012 Mazda3 with SkyActiv powertrain was unveiled at the Canadian International Auto Show in Toronto, February 2011. It comes with Mazda’s SkyActiv-G 2.0-liter, direct-injection gasoline engine...
Skyactiv does not use a generic filter. Last I checked, only Wix and Toyo-Roki made an oil filter that meets the specific skyactiv specs.
If the filter application guide lists engines other than the Skyactiv engines, it was not designed for the skyactiv engines.
Skyactiv G refers to gasoline engine. Skyactiv D is the diesel engine.
Also, as to the above question on 2012 MY. The 2012 model had 3 engine options. 2.0L and 2.5L standard MZR engines (NOT SKYACTIV) and the 2.0L Skyactiv-G.
