Hey There! Didn't see a good answer any where. But, if you were to take your car to the local Mazda, they will put in conventional 5w30 (Idemitsu brand) oil as per the factory specs. Because dealers are also franchises, the parts/service management can also have other brands on hand. At the Mazda dealer I work for, we also have on hand Mobil 1 ESP 5w30.What is the best 5-30 for combatting valve deposit, fuel diltion, etc?
I've been using Mobil 1 5w30 Extended Performance. My mazda dealer uses Castrol per mazda recommended. I prefer the m1. I've always felt engines outlast the rest of the car.Hey There! Didn't see a good answer any where. But, if you were to take your car to the local Mazda, they will put in conventional 5w30 (Idemitsu brand) oil as per the factory specs. Because dealers are also franchises, the parts/service management can also have other brands on hand. At the Mazda dealer I work for, we also have on hand Mobil 1 ESP 5w30.
Total Quartz INEO MC3: 5w30, ACEA C3, SN+ (for LSPI protection), 3.5 HTHS (to combat dilution).
I think its sufficient for "normal" drain ~10kish vs the previous "ESP Formula" with the SA of .6. For the 5w30 variant its HTHS of 3.5 vs Mobil 1 Extended Performance 5w30 HTHS ~3, which I like. Not sure about 0w20 as I was unaware there was an ESP version.I think the EP 0w20 is likely a better choice for most longer drains than ESP. The SA is the same for both at .8, however, it appears what separates ESP from EP is a more shear stable viscosity modifier.
Thanks. I'm confused because the manual seems to say both grades are acceptable. I just bought a 2020 Jetta and that one states specifically to use VW508 which is a 0w-20 so I won't deviate.Use the latest spec 0w20 you can find. SN+ or SP will be fine.
I'm just an old school 5w-40, 5w30 guy and like a lot of us oil veterans, it's just difficult to adjust to using such a low viscosity oil. Some say the thinner oil is s tradeoff for better mileage at the expense of a little less engine protection. But then again, I usually put around 100,000 to 150,000 miles on a vehicle before trading, so it may be a moot point. Anyhow, seriously considering the Mazda 3 2.5S
This thread is for the 2.5 TURBO, which requires 5w30 not 0w-20.Glad I found this thread. I'm looking at a 2021 Mazda 3 2.5S for my son. I downloaded a 2020 user manual and it states use 0w20 if you drive the car in the USA and Canada, 5w30 if driven in Mexico??
Here's the details (as if it could not get more strange)
USA/Canada: use ILSAC GF-V or higher/ SAE 0W-20 engine oil.
Mexico: use API SM or higher, or ILSAC GF-IV or higher/SAE 5w30 engine oil.
So the consensus here is a good quality API SM 5w30 will be fine?
