Originally Posted By: gathermewool
Originally Posted By: horse123
I contemplated typing this because there was an uncalled-for rude tone to your post. But I prefer to fight ignorance more than not give the pleasure to a troll.
XV:
Standard 17 inch wheels with a much larger diameter than the wheels on the imp
Larger front sway bar
Stiffer springs/dampers
Shorter wheelbase
Body and suspension are stiffened overall
Larger brakes
Taller transmission ratio
Larger radiator
Larger fuel tank
You misread my tone. I'm a big Subaru fanboi, but I mentioned pretty clearly that I wasn't sure what exactly the practical differences are, because I haven't had cause recently to check. I asked, because you seemed knowledgeable and could provide a better, more specific answer that might help out the OP, based on what he might need it for. In other words, if he wants a DD for cargo capacity, the Impreza and Crosstrek are nearly identical. If he wants a certain level of acceleration performance or durability in the drivetrain, the two are again nearly identical (except for the items, such as the radiator, that you corrected me on.)
If the OP wants a smaller vehicle, but with increased ride height, and/or wants to take it gently offroad or two something small, then the Crosstrek makes more sense, right?
In context, the OP is looking at this vehicle and it wasn't clear what benefit the Crosstrek provides over the Impreza for a DD, except increased ride height. Cargo capacity is the same (slightly smaller, because of the beefier suspension right?)
Just for giggles I looked up braking distances from 60 MPH on CR
Crosstrek:
Dry: 131'
Wet: 135'
Impreza (sedan - wagon is shorter):
Dry: 129'
Wet: 143'
I didn't see what the base tires were, but it would be interesting to see whether they're the same (I believe the Crosstrek has the same Geolanders as my Forester, stock.)
Subaru loves the junkohama tires. Impreza has the Avid S33B stock. I got those replaced after one winter.
