Mazda ATF-FZ Alternatives (List)
MA
I put together a list of alternatives for the OEM Mazda ATF-FZ automatic transmission fluid. The manufacturer datasheets specify Mazda ATF-FZ as an application. I've included general internet prices and kinematic viscosities as well.
  1. OEM Mazda ATF FZ. $11.00/qt. Color - Blue, KV@40C - unknown, KV@100C - unknown.
  2. Ravenol FZ Fluid. Fully Synthetic. $15.75/qt. Color - Blue, KV@40C - unknown, KV@100C - unknown.
  3. Aisin ATF-MFZ. Synthetic. $9.10/qt. Color - Blue, KV@40C - 27.8, KV@100C - 5.8.
  4. Amsoil Signature Series Fuel Efficient ATF. Full Synthetic. Color - Red. KV@40C - 30.8, KV@100C - 6.3.
  5. Valvoline Max-Life Multi Vehicle ATF. Full Synthetic. $6.48/qt. Color - Red. KV@40C - 28, KV@100C - 5.9.
  6. Valvoline Extended Protection ATF. Full Synthetic. $9.55/qt. Color - Red. KV@40C - 28, KV@100C - 5.9.
As far as I can tell, that's it. Fun fact: Ravenol and Aisin specifically call out the Mazda ATF-FZ part number (0000-FZ-113E01) as a direct replacement.
Anyone know of any other options? Anyone with experience on the alternative fluids? Thanks!
***EDIT - missed a couple
7. High Performance Lubricants - ATF Green. $13.66/qt. Full synthetic. Color - Green, KV@40C - 33.1, KV@100C - 6.37.
8. Mobil Multi-Vehicle ATF. $9.99/qt. Full Synthetic. Color - Red. KV@40C - 33, KV@100C - 6.4.
9. Castrol Transmax ATF/CVT Universal. $5.99/qt. Full Synthetic. Color - Red. KV@40C - 34.2, KV@100C - 7.1.
10. Castrol Full-Synthetic Transmax Multi-Vehicle. $9.00/qt. Full Synthetic. Color - Red. KV@40C - 30.2, KV@100C - 6.0.
11. Liqui-Moly Top Tec ATF 1800. $9.65/qt. Full Synthetic. Color - brownish. KV@40C - 28.5, KV@100C - 5.8
#1 FTW.
When Sis bought her 2012 Mazda3 I bought FZ at the parts counter with a "new member of the Mazda family discount".
There were no posts regarding using alternative fluids.
Where can OE Mazda FZ ATF be purchased for $11 a quart?
PS: I used the Aisin FZ for a D&R in my daughters CX-30 and it worked great. I read on this forum that Mazda will not honor the warranty on their Skyactiv transmission if it comes in with red fluid (rather than blue fluid like the OE FZ fluid...)
Mazda FZ ATF is over $17/quart at the parts counter. I've seen dealerships selling online for $11/quart but with shipping added in, it probably ends up being the same price.
I have used Valvoline or Castrol Import ATF plus the appropriate LubeGard additive in all the Asian cars I have i need over the passed 25 or so years. Changed the fluid every 25 to 30,000 MI and every car I ever traded or sold still had the original transmission with no work done on it. My daughter presently drives an RX 330 with 300,000 miles on it with the original transmission. My other daughter drives a 2006 CRV with 200,000 miles. My wife drives a Mazda CX-9 with 200,000 miles. I'll have Castrol or Valvoline import ATF with lube guard in it and they all shift like they're brand new.
Replying just 'cos I bought some FZ ATF last night at a local Mazda dealer @ C$14.99/1L which is about US$11/1qt.
Also got oil filter for 2.5L non turbo, first time I saw a filter without ADBV too; I never serviced Mazdas in the past.
  • Like
Reactions: pbm
My wife’s 2024 CX-5 uses something different. Don’t see any equivalents for it.
ATF-A7
Last trans drain and fill I used Aisin off RockAuto. A lot cheaper than my local dealer and it was blue. I don’t notice anything different from Mazda FZ that I’ve used for at least 3 or 4 drain and fills prior to switching to Aisin.
Castrol Transmax Universal ATF/CVT has both Mazda MV (older Mazda's) and FZ (newer Mazda's) listed. After doing some research and not having the spec sheets in front of me I would use Castrol Transmax Import with MV listed on the back for older Mazda's. I had a bunch of the Universal stuff on hand so for my new Mazda I used it for the first 2 drains, then the third drain I had OEM Mazda FZ and some Lubegaurd platinum. I think the Universal stuff is viable because I believe it has a higher viscosity which is what FZ has. I have the spec sheets somewhere.
My drain/fill is actual syphon replace from the top, honestly really easy to do. Then turn the air box towards vehicle with no filter on and run to check before putting everything back. There were only so many affordable alternatives in my area. In 30/40K miles I'd do it the same way, finish with the OEM I bought second hand.
I also reset the transmission learning and probably unrelated but cleaned the MAF since I ran it without a filter there for a bit. Acceleration just seemed slow from a complete stop but from what I read it is also just these cars. I try to not use sport mode (I don't think I should have to).
We bought a 2017 CX-5 for my wife last year and like all used vehicles I buy I perform a complete fluid refresh. What came out from the previous owner appeared to be red Valvoline Maxlife. Now I've compared Mazda blue FZ to Valvoline MaxLife Multi-Vehicle ATF and the the viscosity is difference right out of the bottle is night and day on a 85F day. FZ is like water. So the question is the same as 0W20 motor oil for that is recommended in US sold naturally aspirated 2.5L Mazda's vs. the rest of the world calling for 5W30, is Mazda FZ low viscosity called for to meet strict North American CAFE requirements? I did end up putting in Mazda FZ but it's watery thinness did not leave me feeling to confident for longevity.
