Mazda 3 needed few things
Canuck - moved to —> California —> Texas —> ???
The wheel bearing, drive shaft seal and strut bearing needed to be changed. My fault for letting it all sort of pile up like this, but I finally tackled it.
The drive shaft seal started leaking after I changed the shaft, lesson learned for me, change the seal while at it.
I want to say that my local O'Reilly has very good quality tools to rent. Everything looked new and not beaten up and no components were missing.
How did you replace the front wheel bearing? I thought that they had to be pressed out and in? Thanks for the post.
Take the snap ring out and use the tool he borrowed. Essentially a big bolt with the proper sized backing plates.
South Main Auto has some good vids of doing press-out bearings with such a tool.
You've lived a good life if you got that bearing out without taking the knuckle off.
+1 Its usually easier to pull the knuckle and press it.
Whenever I use a loan-a-tool program, I always inspect the tool for missing/damaged pieces before I leave the store. Have them right down any deficiencies on the receipt. Looks like this job went well.
I rented the bearing press kit, fourth picture down. It helps if you have an impact gun. I have an electric one which helped tremendously.
I don't know what you guys are talking about, I rented a macpherson strut compressor from my local CT and it was brand new. Other tools I have rented have some wear but they are always complete. I have rented from both CT and Partsource probably eight to ten times by now.
