I'm trying to change my oil this morning on a 2007 Mazda 3 2.3L engine. Removing the plug from the filter cartride drained just a bit of oil. Then removing the filter drained a bit more. Probably around 1 quart. It was coming out as a drizzle towards the end but still was normal viscosity and a bit warm (I had warmed the engine first).
As I had recently checked the dip stick and saw normal oil levels I didn't think of lost oil. My first though was perhaps the engine is in an odd position and used the sarter motor to turn it over a bit. That did produce a bit more oil on certain turnovers (not all) but not a normal oil flow.
Then I thought, perhaps somehow, the car was very low on oil. So, I added 3/4 Qt to see what happened. If it was low on oil, I expected to see it drain through. That didn't happen. Again, turning the engine produced a bit more draining at points but still not a normal flow and not much oil has come out.
I have no idea what is going on. Internet searches and searches here on BITOG are not turning up the right subject matter with maybe one exception, a clogged drain channel. I'm going to look for that in a moment.
Even if I replaced the filter, added oil, etc. I'm concerned this indicates a more serious problem and wonder if the car is even drivable. As it is on my driveway right now and my wife plans to use it tomorrow, advice is needed urgently! Thanks!
