Maybe I'm crazy - changing engine oil at 500 miles
Lake Jackson Tx
At 500 miles I've decided to change my oil. I know Toyota says 10,000 but the initial break in is the most important as it can really determine the overall life of the engine or whatever component you're changing the fluid in. Maybe I'm old school not really crazy about the Mobil 1 either went with Castrol edge 0w20.
From here on out I'll probably do four to five thousand mile oil changes. Oils cheap replacing drivetrain components is not. Probably a little overkill but I would rather be safe than sorry.
Excess oil changes can accelerate those valve deposit problems on the direct injection engines.
How so? I'm curious as to how clean oil that's a good brand would leave behind deposits on valves? I could be all wrong about this but that would be like saying waxing your vehicle too often can make the paint come off.
I'm a 6 month or 2x per year oil change guy. Absolutely nothing wrong with Mobil 1.. ran Mobil 1 Advanced Fuel Economy 0w20 in the wife's 17' Corolla.
6 month or twice a year? How is that even close to a reasonable interval?
For my Sonata that would be 10k mile OCIs.
For my Jeep that would be 1k mile OCIs.
Well depending on one's driving, for me my oci schedule works fine.
OK, and leaving DI caused, heavily fuel diluted oil in the sump for greatly extended OCIs can do even more harm than IVDs will.
The op also has the factory added port injection system to 'take care of' those pesky IVDs as well.
It's not that Mobil is a bad oil I just think for the money there's better.
Castrol? Or what else?
And why do you think that?
Castrol being number one and Valvoline being second. I've seen a few engines that has ran the Mobil 1 and though it wasn't sludged up it had a lot of varnish built up in certain areas.
I've always seen engines absolutely spotless with Castrol and a couple with the Valvoline. Most people buy the Mobil 1 because of the advertising and the name.
Originally Posted by spasm3
I dumped the oil in my cx-5 at just under 400 miles. I like to get the metal laden oil out early.
So what's the filter for?
Have you not noticed that the oil in brand new engines frequently show elevated metals in uoa tests, despite having a filter. Filters catch the big stuff.
And you're sure these engines have run ONLY Mobil 1, Castrol and Valvoline their entire lives?
I'm sure if it was an actual issue, there would be a mention in the owners manual saying "do the first oil change at X miles. After that, do them at Y miles."
