- Joined
- Aug 15, 2024
- Messages
- 609
Never said amsoil made that claim. Pablo stands behind that belief apparentlyWho said Amsoil said that?
I don’t think people understood the nature of my comment or the sarcastic ridiculous rhetorical exchangeI believe all of the majors, they draw from a broad slate. Do they use XOM? I would assume so, they have a diverse range of PAO base oils that would make them a logical inclusion.
I don’t. Some people might I don’t know.Never said amsoil made that claim. Pablo stands behind that belief apparently
Did it burn any oil? Seems like there's lot of reports of those K series engines burning oil later in life, but they seem to respond well to a Valvoline Restore and Protect cleanup.XL and OE were my choices on my high mileage commuter. I changed at 10k intervals and did a lot of highway mileage in a K24 powered CRV. Always felt that Amsoil OE gave me the best value. And a clean engine. I pulled the valve cover off twice to replace gaskets and check valve clearances (perfect each time) and it was spotless. Gave that car to my niece at 303K miles. Ran great.
I like Amsoil products and I like the online experience. But more importantly to me, I like ordering the product I need vs looking on the shelf or going to different retailers to get different things. IE - I go through a lot of Amsoil's All-In-One diesel fuel treatment. Not sure where I can find a reasonable equivalent as Walmart only sells Power Service and Howes I believe. I can order oil, grease, fuel treatments, etc. in one shot. Its just convenient, and being a dealer or PC, the costs are similar to name brand products everywhere.
Yep. I can show what $2 per qt maxlife 0w20 synthetic, used exclusively on our 2018 rogue from new to 85k did. I changed it every 5k religiously and when I snaked a scope down the valve cover it was pristine. Not a discolored spot to be had. Maybe supertech could have done the same, but I know valvoline did for sure.I could show you similar examples with Mobil 1, too. Or other brands.
The latest SDS for their Signature Series motor oils states the PAO content is 5-10%, from which I gather the balance of the base oil blend is likely Group III (certainly not ester, PAG, or AN). Only a GC scan can tell for sure. At such a low PAO level, esters are not technically needed although may be present.Just a note...Amsoil uses mainly Group 4 PAO basestocks with Group 5 Ester base stocks as their soluble additive carriers in their Signature Series oils.
It did, but not badly. At its worst it was burning about a quart per change (10k miles). It would have been a good candidate for Valvoline Restore and Protect, but sadly its gone now. Niece traded it for a new civic.Did it burn any oil? Seems like there's lot of reports of those K series engines burning oil later in life, but they seem to respond well to a Valvoline Restore and Protect cleanup.
Pretty sure you can't backwards engineer an oil with an SDS.The latest SDS for their Signature Series motor oils states the PAO content is 5-10%, from which I gather the balance of the base oil blend is likely Group III (certainly not ester, PAG, or AN). Only a GC scan can tell for sure. At such a low PAO level, esters are not technically needed although may be present.
SDS for SS Series Oils
Of course not, but there are some valid conclusions that can be drawn if one has formulation expertise.Pretty sure you can't backwards engineer an oil with an SDS.
I kinda wonder if Amsoil's OE line would even exist; the label itself not necessarily the formulation that goes into it, if folks weren't convinced SS could somehow void their warranty.You can tell, to a limited extent, what Amsoil lines they save for the top tier base oils. Look at the price, oxidation value and Noack. OE/XL - dry - similar to off shelf synthetics, priced accordingly. SS/Dominator/some Euro oils (Euro line varies in price significantly from $11-$17/qt) show virgin oxidation >40. Even with that said, you can't conclude what exactly and how much of each are being used. Then you also have additive levels, type/quantity of VM, type of AO etc....
Amsoil has provided more than any other company data that shows their SS is very very good.
RL/HPL go all out across entire range other than RL's OE range. Smaller market share. Amsoil has had to cater/cave to expand.
AMSOIL Signature Series is a great choice but if you're looking for max shear stability have you considered Red Line? To this day the most shear stable oil I've seen based on many used oil analysis. I don't think it's due to the VM type either, but rather lack of VM. They use less VM. Their 0w40 is ok but I'd opt for Red Line 5w40.Im going to order a fresh batch of Amsoil 0w-40 through Pablo, run it and test it out. Post it in the used oil analysis section. See how well it does.
I wish Amsoil had a non-Euro 5w-40.
When this website starts touting 10,000 mile oil changes the thought which comes to mind is contamination, sludge, etc. I have flashbacks of all these internet mechanics showing blown engines where its clear the oil was not changed timely.
So I came upon this video where a man says his fleet business Ford Transit Connect with 82000 miles that has been changed every 10000 miles with Amsoil is super clean! He opens the engine and reveals nothing but a clean cam/chain and interior engine area. This really has my eyes open and changes my attitude. I guess you just have to have a certain oil to do the 10,000 mile changes otherwise it wont work. I dont think I would trust SuperTech 10,000 mile oil changes...that one more for the 5000 mile variety. However we can put our faith in the Amsoil Signature Series!
TrollI can pour in a $5 can of Gunk Engine Flush and run for 5 minutes, and see the same resulting pictures.
Overbased cleaners i.e. Amsoil, Mobil, etc, eat ALL seals and gaskets.
WrongI can pour in a $5 can of Gunk Engine Flush and run for 5 minutes, and see the same resulting pictures.
Did you just wake up today, choose violence, search for Amsoil, and troll every thread?I can pour in a $5 can of Gunk Engine Flush and run for 5 minutes, and see the same resulting pictures.
