Well not sure if any base oils used in XL specifically come from Exxon. I think not. Hence my statement.Congratulations you support ExxonMobil
Your own words "Not here, but less wear, cleaner internals, not supporting ExxonMobil."
Supertech 20K is good oilJust like there’s no technical proof Mobil 1 Extended Performance outperforms Supertech 20k? It’s a disingenuous argument. Higher quality ingredients exist. If you need them or not is the real question.
I don't doubt Amsoil's ability to make it to 20,000 miles, nor do I doubt it's cleaning ability. My point is other oils can do it too.Well not sure if any base oils used in XL specifically come from Exxon. I think not. Hence my statement.
Stick to 5K intervals or below and it shouldn't be much of a worry with any full synthetic oil, but if you are worried Valvoline Restore and Protect is the only licensed oil that is available pretty much at any store that sells oil that is proven to clean piston ring deposits.Now I learn to worry more about the piston rings then the valvetrain. I do frequent oil changes, so valvetrain is not my concern.
Piston deposit problems aren’t prevented by oci length. It’s directly tied to oil quality and engine/conditions. I second Valvoline Restore and Protect available at Walmart. AMSOIL Signature Series and HPL also keep pistons clean.Now I learn to worry more about the piston rings then the valvetrain. I do frequent oil changes, so valvetrain is not my concern.
I've been using Valvoline Restore and Protect.Piston deposit problems aren’t prevented by oci length. It’s directly tied to oil quality and engine/conditions. I second Valvoline Restore and Protect available at Walmart. AMSOIL Signature Series and HPL also keep pistons clean.
When this website starts touting 10,000 mile oil changes the thought which comes to mind is contamination, sludge, etc. I have flashbacks of all these internet mechanics showing blown engines where its clear the oil was not changed timely.
So I came upon this video where a man says his fleet business Ford Transit Connect with 82000 miles that has been changed every 10000 miles with Amsoil is super clean! He opens the engine and reveals nothing but a clean cam/chain and interior engine area. This really has my eyes open and changes my attitude. I guess you just have to have a certain oil to do the 10,000 mile changes otherwise it wont work. I dont think I would trust SuperTech 10,000 mile oil changes...that one more for the 5000 mile variety. However we can put our faith in the Amsoil Signature Series!
Even Mobil's regular full synthetic oil are advertised for 1 year now.Mobil did once produce "Annual Protection" oil. I never got into it, dont know what happened to it. I just found it ridiculous to put oil in the car and change it once per year.
SuperTech at 20k? Once a year Mobil? Thank you but no. I had a good laugh.
It’s not really that ridiculous. I do one year oil changes on my Corvette, as do many late model Corvette owners. I even used to do two year oil changes on my previous CorvetteMobil did once produce "Annual Protection" oil. I never got into it, dont know what happened to it. I just found it ridiculous to put oil in the car and change it once per year.
It is easy to keep engine internals clean today. Nearly all of the 0W-xx syn oils and really, all quality synthetics can do it . Good luck keeping that timing chain and variable cam systems healthy with thousands of miles of circulating particulates, contaminates and combustion by products due to extended oil change intervals though.This really has my eyes open and changes my attitude. I guess you just have to have a certain oil to do the 10,000 mile changes otherwise it wont work.
My Chevy LS3 is still together @ 110,000 miles on Mobil 1 so….YAY!why did the engine need opening at 82k?
Does Mobil 1 include unlimited data?My Chevy LS3 is still together @ 110,000 miles on Mobil 1 so….YAY!
I bought a ton of Mobil 1 Annual Protection on clearance - it was 60-70% PAO - but, never ran it past the OLM range.Mobil did once produce "Annual Protection" oil. I never got into it, dont know what happened to it. I just found it ridiculous to put oil in the car and change it once per year.
Only for the cell towers in coastal AlabamaDoes Mobil 1 include unlimited data?
