Long time lurker very rare poster. I just got a UOA on the wife's Swagger Waggon and I figure you guys are the only ones besides me likely to care about the results.
The car had all it's oil changes done at the dealer for the first 50,000 miles (while the warranty was in place) but I'm not convinced they actually did it every time or at the very least they used cheap oil because the oil looked like garbage the first time I changed it.
Since I have been doing the oil changes (starting at 50k) I have only used Max-Life, 5w30 in the winter and 10w30 in the summer.
Unlike when I drained the dealer oil the first time every other time I've changed it the oil has come out super clean so I guessed it was likely I could go past the 5000 mile Toyota recommended interval but I figured I should have some data to back that up.
2 oil changes ago (at 85k) I dosed the engine oil with Sea-Foam about 50 miles before I changed the oil. I was a little worried there would be some residual Sea-Foam in the oil for the test.
Planning on moving to the suggested 7k OCI for the next couple of oil changes and then test again at 109k
