03 Maxima with HID headlights. Have a couple of issues.
1) Drivers side low beam keeps going out. I've tracked it to this connector, is that a 9006? Does that mean that if necessary, I could bypass the ballast, go straight to LED?
2) The prior owner bent both bulb holder retainer clips. So both low beam bulbs flicker over mumps. I found used replacements on eBay for different years that fit, except for this one groove. Prevents a D2R HID light from going flush into the clip. What is it for, was planning on grinding it off.
