03 Maxima with HID headlights. Have a couple of issues.
1) Drivers side low beam keeps going out. I've tracked it to this connector, is that a 9006? Does that mean that if necessary, I could bypass the ballast, go straight to LED?
2) The prior owner bent both bulb holder retainer clips. So both low beam bulbs flicker over mumps. I found used replacements on eBay for different years that fit, except for this one groove. Prevents a D2R HID light from going flush into the clip. What is it for, was planning on grinding it off.
![[Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2019/05/full-39849-33039-inkeds_l1600_4_li.jpg)
![[Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2019/05/full-39849-33038-20190527_145641.jpg)
