Max Blend 5/30
Millbrae, CA
MAX BLEND 5/30
Vis @ 100-11.5
Vis @ 40-66.7
VI- 167
TBN- 6.28
FE-7
CR- AL-2
PB- CU- AG- TI- SI-6
B- NA-410
K- MO-306
P-776
ZN-868
CA-2282
BA- MG-11
SB- V-<1
Thanks Bruce! This is the stuff in my cavalier right now, thanks for running it :)
Edit: I have to say that the TBN is a little lower than I thought it would be, I thought it was like 8 or more. Probably will only do 5k on this. (was going to do 6, 7)
TBN seems far too low.....listed TBN is 8.3, and you've got 2200ppm Ca and 410 ppm NA.....has to be higher than 6.2???
Not calling you out, Bruce.
I just thought with those additive amounts the test DID find, TBN would be higher, that's all.
It also depends on the testing method used. Different TBN testing methods result in different results.
