Mobil 1 15W50 EP
Mobil 1 15W50 EP Virgin Sample - Analysis by Oil Analyzers Inc
Al 2
Ba B 298
Ca 3194
Cr Cu Fe 1
Pb Mg 16
Mo 95
Ni P 1297
Si 6
Ag Na 8
Sn Zn 1447
K V Ti V100C 18.30
TBN 9.98
This VOA has higher levels of some additives than this older VOA of the API SL version. Maybe it's a change for the better. https://bobistheoilguy.com/forums/threads/m1-15-50-red-cap-vs-15-50-gold-cap-ep.83398/
"And the EP Gold Cap: SL/CF...
DATE: 2-4-08"
ALUMINUM: 0
CHROMIUM: 0
IRON: 1
COPPER: 0
LEAD: 0
TIN: 0
MOLY: 82
NICKEL: 0
MANGANESE: 0
SILVER: 0
TITANIUM: 0
POTASSIUM: 0
BORON: 99
SILICON: 5
SODIUM: 4
CALCIUM: 2261
MAGNESIUM: 12
PHOSPHOROUS: 1013
ZINC: 1201
BARIUM: 0
SUS VISC. @210F: 85.4
Cst Visc. @100C: 16.85
Flashpoint: 460
Fuel %: —–
Antifreeze %: —–
Water %: 0.0
Insolubles %: 0.0
TBN: 9.8
Oil looks pretty stout. It does look like they boosted the additives which is unusual since most oils seem to cut the additives with each new formula.
When the 15W50 EP Gold cap came out and basically replaced the red cap, people bought it up and used in the same severe apps as the previous red cap. The adds for anti-wear were lower among some other changes and this had an adverse effect on some high stress engines that saw accelerated wear or just blew up unexpectedly (mostly racing stuff). A lot of people were turned away from Mobil 1 by this and moved on to something else. I say it was a blunder to suddenly discontinue the old red cap and lessen the toughness of a tried and true oil that folks have come to know and trust. I guess this new VOA shows they are now tacitly admitting the problem with the earlier EP formulation in this grade. On-the-fly changes like this and unreliable availability of certain grades of their products is a negative with Mobil 1 oils for me. I guess it's ok if you stock up when the stuff is available or on sale.
I was a continual user of the old red cap until they discontinued it.
You know what the pity is, even though they brought back the silver-cap 15W50, it's impossible to find. Every place that even stocks such a heavy oil sells only the EP version.
Costco tried the silver cap, only to find that the palettes mostly accumulated dust while everyone bought the 30 weights.
There is one specialty auto supply store that has pretty much all the Mobil 1 grades, including the ESP variants, but I'm not going to pay full price when there are other options that often go on sale.
To add to the misery, Pep Boys has now taken away one of the few available alternatives and will no longer carry Pennzoil Platinum 15W-50.
There is one specialty auto supply store that has pretty much all the M1 grades, including the ESP variants, but I'm not going to pay full price when there are other options that often go on sale.
My local Walmart has silver cap 15w-50 in gallon jugs for $22.85, (was $21.97 last month
You're lucky.
A trip to the closest Walmart will cost me $8 in fuel at today's prices. And sometimes they have the mother lode of oil choices, other times it's bare, so it would also be a gamble that might not pay off.
I've avoided Mobil 1 Extended Performance due to the extra cost, and questions about its composition. Glad to see that the thick version at least appears to be a solid oil, but I don't think I'll be swayed.
