Manual Transmission Calling for ATF. Why?
That sounds like ancient lore - BUT there could be some plastic used at some point that didn't like certain base oils. Hard to know.
This said, actually getting "cute" sure, no willy nilly, but there actually is enough room to improve in this space.
I don't know, Redline oil came to mind- claims it cost one customer $4500......so with all the other oils out there why not take his advice.
The thread is going a little more towards the topic of “what’s a good alternative” I was hoping someone could answer why chemically or mechanically do some manual transmissions specify ATF vs an MTF.
I’ll open the “is there a better fluid than the gm specified fluid” thread once I get some VOAs done of the various fluids.
What vehicle will you be purchasing that has ATF as OEM fill ?
My old 1990 Mustang with T5 transmission also used ATF. I put Redline MTL.
I recall many years ago some confusion when time to service my 1988, 4 cyl Chevy S-10 manual gear box as Chevy changed from gear oil to ATF around that time from one year to the next. The transmission was the same transmission but chevy said gear oil then changed to AFT , may have been in the middle of that model year?
My guess it was EPA related but I have no idea?
Cadillac ct5v Blackwing
My niece had a nineties S10 with the 4 cylinder and I think it had an NV1500 5 speed. I changed the lube and put Royal Purple synchromesh fluid in it as that's what the Internet said to use. A few months later that stupid thing started not going into gear like the sychros couldn't grab anymore. I dumped a bottle (maybe two) of Lubegard limited slip additive into it and it was fine after that.
Go back and look at some of the things @MolaKule wrote on the topic.
ATF isn’t great in all attributes but it works well for many.
There also used to at least be ATF that had higher levels of adds for use in an MT.
My dad went through transmission school in the 70's and then it was explained that the only real reason that ATF, a MTF like synchromesh or 80W90 being used in different transmissions from a factory fill standpoint had to do with the shift feel depending on the model/type of manual transmission, all of the lubricants protected the same otherwise. I'm sure a lot of that has changed since then but it was a pretty good explanation as to why certain fluids were used in certain manual transmissions. I'm sure the ATF and a thinner fluid like synchromesh does free up some power loss compared to a thicker 80W90 especially in the colder weather.
I finally got my VOA back for the AC Delco fluid being recomended for this transmission:
Seems rather unremarkable. I'm guessing I can replace it with either HPL 75w75, HPL 75w-80, RP Syncromax (very close 40C and 100C visc to the AC Delco) or Amsoil MTF.
The cold shifting performance of the transmission is excellent so I'm wondering if it's worth the risk in going up in viscosity some.
Any thoughts?
If I recall correct, I owned a 1988 s10 4 cyl truck, was told the fluid changed in the middle of that year? I may be wrong but thats what I recall.
Cold shifting in my manual was slower when it got colder. I went from recommended ATF+4 to MobilTrans SHC-DC and it worked fine, just shifted slower.
I think the ATF+4 would have been fine to keep in the G56.
Many years ago SAAB 99's used 10-30 in their manual transmissions.
SAE 80W is right in the 20 to 30 grade motor oil vis range.
But motor oil doesn't have the sulfur-phosphorous compound additives to combat extreme pressure galling.
Maybe more of an issue with a 396 big block in front of that Muncie M21 than in an import weighing 2300 lbs with a 110 HP 4 banger
I haven't read through this, but I think part of it is that the gear oils generally used would eat the bronze on the bushings. My YJ was spec'd for ATF. You could use Bronze safe gear oil in the YJ transmission instead.
There are no hypoid gear in most so the "protection" requirements arent very high
ATF is aprox. the correct viscosity, stays thin enough in winter.. and works.
IF you get an MTF of the correct viscosity and gl-4 that also should work.. may have exceptions for fringe cases.
such as Porsche and Subaru that have hypoid gears and shared sump arrangement.
Porsche's have separate clutch and gearbox fluids. You need gear oil for the gearbox/front differential and PDK fluids for the clutches. Yellow is PDK fluid, green is gear oil.
Edit: it appears some versions do use a combined fluid.
