Coasting in neutral has left the engine to rely on fuel to keep itself running, so it's using fuel when coasting in neutral. Most modern fuel injected cars shut off the fuel supply when coasting in gear until RPMs slow to near-idle..then the fuel supply is restored. You'll use less gas using engine braking.
