Originally Posted By: scott37300
Here is another I copied from advanceauto website from the maxlife:
MaxLife DEX/MERC ATF contains a blend of base oils and a unique additive package to help extend the life of transmissions with over 75,000 miles. It is formulated to maximize transmission performance, reduce transmission wear and improve and maintain smooth shifting longer than conventional fluids. MaxLife DEX/MERC ATF is compatible with new and rebuilt transmissions and will not void new car warranties. Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 295 and 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
I highlighted in red where they say it won't void new car warranties. Wonder why advance would put that on their website if GM only allows their own dexronVI to be used? Seems like if I did use maxlife and had a trans problem and GM denies warranty because of that then advance would be liable since they say it won't void warranties?
They have lawyers writing this things now or at least proofing them. Yes it doesn't void your warranty, but if you have a transmission failure and it is traced back to the fluid. Then they will deny you on grounds that you are using an unapproved fluid.
