Make links blue again
ME
Can we do this please? I'll insert an inline link and you barely know it's a link because it's the same color as the text, in the default skin. It's underlined, but barely.
Originally Posted by Warstud
While there at it....please fix the time. it's off 5 hours.
The time is fine. You just need to go into settings and set your time zone. It kinda defaults to some UTC time of 0:00.
Thanks...I fixed it.
Originally Posted by Drosselmier
Where do you find Settings ?
It's not really called Settings. At the top right of the homepage click your name then click preferences. Change whatever then save changes.
It's blue for me with UBBCentral theme. I changed it back to Red/Gray and the link is Red.
What theme are you using?
I use Zen and the link is almost invisible. Just a thin underline to it in very light blue.
Here is an example of it
[Linked Image]
Can you tell where the link is in the screenshot?
A lot of my links I have had to add an underline to make it visible. No idea how many links I miss because of it.
I guess I'm using zen, by default? Will play with themes I guess.
