Originally Posted By: CurtisB
My concern with a filter magnet would actually be with the placement of the filter bypass valve. If a magnet has particles trapped against the filter housing, could a high pressure bypass scenario dislodge some of the trapped metals and enter the bypass valve (being if the filter has a dome end bypass).
"high pressure bypass scenario" ... humm. When an oil filter goes into bypass, there really isn't any "high pressure" involved. And the oil flow volume going through the filter really doesn't change in the amount since the oil pump is positive displacement ...it just changes flow paths.
Now if for some reason the magnet placed on the oil filter was in a flow "dead zone" (around the dome end), and all of a sudden the bypass valve opened it got some of the oil flow volume swept past it, then it might be possible some debris could be dislodged if the bypass flow was significant. But I don't think this situation really occurs because bypass valves usually just crack open and let a small portion of the total flow through the valve. To be safe, just don't put the magnets on the dome end of the filter, but rather on the sides of the can like a FilterMag does.
I myself would be concerned with the sudden entry of metallic wear particles, some of which would have been trapped in the filter media without the magnet present.
In a bypass event, there is still some oil flowing through the media, so what's trapped in the media, stays in the media. It doesn't magically jump off the media against the direction of the oil flow going through the media.
