Originally Posted By: cjohns79ut
OCI every 3-4 k. Heard too many horror stories about engines using oil once switched over to synthetic.. I drive short distances daily is the main reason of using synthetic
Older issues, with older formulations of synthetic. So, more of an old wives tale at this point.
Switch to a synthetic or High-mileage, top-off the initial loss(if any) from the initial switch. You're not going to start going through quarts and quarts of oil loss. If anything, maybe a quart over 3,000 initially(at most), but things do settle down.
Not a bad idea to stay with 3-4 thousand initially on synthetic, since it will probably do 'some' sort of cleaning, but after 10,000 on synthetic you can easily go at least 5,000 miles(7,500 as a cap depending on conditions) at the very least, IMO.
The sweet spot for most oils/engines seem to be between 3,000-6,000 miles. So really, especially swapping to synthetic, draining the oil between 3,000-4,000 is right when it's just gotten to it's best. At 'that' point, you have quite a while before the oil 'wears out'.
DISCLAIMER: This is under the assumption that the engine/application you are speaking of is in generally sound order(no malfunctions etc). Make sure to check that PCV valve on all of your apps, folks!
