Dyson Analysis
Oil Brand/Weight : M1 SS 10w-30
Oil Filter: AC Delco PF35
Type Equipment : 93 Pontiac Firebird/Trans Am, 5.7L V8 LT1 motor, 6 speed manual tranny
Miles on oil : 5300
Total Mileage : 163377
Notes: Milage is about ~50/50 city/hwy. Car is nearly always driven for at least 20min so oil always has enough time to warm up. The car generally doesnt see much over 3000rpm on the streets (I cruise at ~2000rpm on the hwy) but this interval does have two Autocross events on it where it got flogged a bit.
Results ppm/% Comments (blank=normal)
Wear
Copper 4 low
Iron 14 slight elevation
Chromium 1 low
Lead 9 normal
Aluminum 4 low
Silicon 17 elevated
Tin 0 low
Additives
Molybdenum 51
Sodium 4
Magnesium 48
Zinc 751
Potassium 0
Phosphorus 639
Calcium 2290
Physical Properties
Water negative
Fuel negative
Antifreeze negative
Soot 0
Oxidation 13% (26 on 0-199 scale)
Nitration 18% (36 on 0-199 scale)
Sulfur 0
TBN 8
Vis@100 C 10.5
Any comments? This is my first analysis ever so I'm not sure what to make of it. Terry did say everything was pretty good aside from the silicon and iron.
Right now it has a homemade cold air kit with a conical K&N filter. I made it way back before I knew any better so I suspect it has some leaks in it which are contributing to the high silicon. I'm probably going to switch back to the factory setup since I dont do much drag racing anymore and the extra power is the last thing I need autocrossing. Hopefully that will get the silicon
Jason
Miles on oil : 5300
Wear
Copper 4 low
Chromium 1 low
Lead 9 normal
Aluminum 4 low
Silicon 17 elevated
Tin 0 low
Additives
Molybdenum 51
Sodium 4
Magnesium 48
Zinc 751
Potassium 0
Phosphorus 639
Calcium 2290
Physical Properties
Water negative
Fuel negative
Antifreeze negative
Soot 0
Sulfur 0
TBN 8
Vis@100 C 10.5
Jason
