code:
Here's the teutonic M1 5w-40
Spezifikationen/Freigaben
Mobil 1 5W-40 erfüllt die Spezifikationen:
ACEA A3, B3, B4
API SL, SJ, CF
Mobil 1 5W-40 ist freigegeben gemäß:
Daimler Chrysler 229.3
Porsche Approved
Volkswagen 502.00/505.00
Typische Produktdaten
Mobil 1 5W-40
SAE Klasse 5W-40
Viskosität, ASTM D 445
mm²/s bei 40ºC 87.2
mm²/s bei 100ºC 14.6
Viskosität, sindex, ASTM D 2270 175
Sulfatasche, wt%, ASTM D 874 1.2
HTHS Viskosität, mPas bei 150ºC , ASTM D 4683 3.80
Pourpoint, ºC, ASTM D 97 -54
Flammpunkt, ºC, ASTM D 92 238
Dichte bei 15 ºC, kg/l, ASTM D 4052 0.857
Mobil 1 5w-40 Synth S
Specifications & Approvals
Mobil Synt S 5W-40 meets or exceeds the following industry specifications:
5W-40
ACEA A3, B3, B4
API SL,SJ,EC,CF
Mobil Synt S 5W-40 has the following builder approvals:
5W-40
BMW LL-98
DC 229.3
VW 502 00; 505 00
Opel GM-LL-B-025
Porsche Approved
Typical Properties
Mobil Synt S 5W-40
SAE Grade 5W-40
Viscosity, ASTM D 445
cSt @ 40º C 84
cSt @ 100º C 14.2
Viscosity Index, ASTM D 2270 175
HTHS Viscosity, mPa·s @ 150º C, ASTM D4683 3.6
Pour Point, ºC, ASTM D 97 -39
Flash Point, ºC, ASTM D 92 220
Density @15º C kg/l, ASTM D 4052 0.855
Synth S V Special
Mobil Synt S Special V 5W-40 meets the following industry and builder specifications
API CF X
API SJ x
ACEA A3 x
ACEA B3 X
Mobil Synt S Special V 5W-40 has the following builder approvals
VW 505 01 X
Ford WSS-M2C917-A X
Mobil Synt S Special V 5W-40 is recommended for use in applications requiring:
VW 500 00 X
Typical Properties
SAE Grade 5W-40
cSt @ 40°C 92.8
cSt @ 100°C 14.1
Viscosity Index, ASTM D 2270 156
Sulphated Ash, wt%, ASTM D 874 1.2
Total Base, mg KOH/g, ASTM D 2896 9.7
Pour Point, °C, ASTM D 97
Flash Point, °C, ASTM D 92 239
Density @ 15°C, kg/l, ASTM D 4052 0.857
Esso Ultron 5w-40
Esso Ultron 5W-40 meets or exceeds the following industry specifications:
API SL/SJ/CF
ACEA A3,B3,B4
Esso Ultron 5W-40 has the following OEM approvals:
BMW LONGLIFE OIL 98
Volkswagen 502 00 and 505 00
Mercedes Benz MB 229.3
Peugeot PSA E/D Level 3
Porsche
Opel GM-LL-B025
Typical Properties
Esso Ultron 5W-40
cSt @ 40º C 84
cSt @ 100º C 14.2
Sulfated Ash, wt%, ASTM D 874 1.02
HTHS Viscosity, mPa·s @ 150º CASTM D4683 3.6
Delvac 1 SHC 5w-40
Mobil Delvac 1 SHC 5W-40 meets or exceeds the following industry and builder specifications:
ACEA E4/B4/B3
API CF
Mobil Delvac 1 SHC 5W-40 has the following builder approvals:
Mack EO-M
ZF-TE-ML 04C
Volvo VDS-2
Renault RVI RXD
Deutz TBD 616 Marine
Daimler Chrysler MB 228.5
MAN 3277
MTU Type 3
Mobil Delvac 1 SHC 5W-40 is recommended for use in applications requiring
API CE
Typical Properties
SAE Grade 5W-40
cSt @ 40ºC 93
cSt @ 100ºC 14.5
Viscosity Index, ASTM D 2270 172
Sulphated Ash, wt%, ASTM D 874 1.8
Total Base #, mg KOH/g, ASTM D 2896 16
Pour Point, ºC, ASTM D 97 -54
Flash Point, ºC, ASTM D 92 226
Density @ 15ºC kg/l, ASTM D 4052 0.86
Delvac 1 CI4 PLUS
Mobil Delvac 1 Meets or Exceeds the following industry and builder specifications:
5W-40
API CI-4 PLUS/CI-4/CH-4/CG-4/CF-4/CF/SL/SJ X
ACEA E5/E4/E3 X
Caterpillar ECF-1 X
Cummins CES 20072/20071 X
Detroit Diesel Power Guard Oil Specification X
Global DHD-1 X
JASO DH-1 X
Mobil Delvac 1 5W-40 has the following builder approvals:
5W-40
Cummins CES 20078/20077/20076/20075 X
Mack EO-N Premium Plus 03, EO-M Plus X
Mercedes Benz 228.5 X
Volvo VDS-3, VDS-2 X
Mobil Delvac 1 5W-40 also recommended for use in applications requiring:
5W-40
Renault RVI RXD X
Typical Properties
SAE Grade 5W-40
cSt @ 40ºC 102
cSt @ 100ºC 14.8
Viscosity Index, ASTM D 2270 151
Sulfated Ash, wt%, ASTM D 874 1.35
Total Base #, mg KOH/g, ASTM D 2896 12
Pour Point, ºC, ASTM D 97 -45
Density @ 15ºC kg/l, ASTM D 4052 0.854
Delvac 1 CI-4
Mobil Delvac 1 5W-40 meets the following industry and builder specifications:
API CI-4/CH-4/CG-4/CF-4/CF/SL/SJ
ACEA E5/E4/E3
JASO DH-1
Global DHD-1
Detroit Diesel (4-stroke) DDC 7SE270
Caterpillar ECF-1
Mack EO-M, EO-M Plus, EO-N Premium Plus
Cummins CES 20078/77/76/75
Volvo VDS-3, VDS-2
Mobil Delvac 1 5W-40 is recommended for use in applications requiring:
Cummins CES 20072/71
Renault RVI RXD
Typical Properties
SAE Grade 5W-40
cSt @ 40ºC 102
cSt @ 100ºC 14.8
Sulphated Ash, wt%, ASTM D 874 1.35
Total Base # , mg KOH/g, ASTM D 2896 12
