Lucas oil leak
Cape Coral Fl.
04 chevy express 2500 base V8 . Have oil leak at rear of engine. $1000 to fix so thinking of trying Lucas stop leak. Has anyone used it and what were the results. Thank you for any info. jz
How much is it leaking? You can buy a lot of oil for the cost of a rear seal job if that is what it is, have you checked the valve covers?
I am not a fan of seal swellers, they can cause more problems than they fix.
When my 07 F150 had an RMS leak AND an oil pan leak I tried almost EVERY stop leak snake oil made. I had to finally break down and face reality; FIX THE LEAKS!
Since you're in Florida, try a 20W-50 high mileage oil, Napa occaisionally puts their house brand on sale for a decent price, Castrol GTX High Mileage is the most affordable. Seems most brands have discontinued 20W-50 high mileage or they only sell it by the quart.
All LSx engines use a PTFE rear main seal, Rarely is it the rear main that leaks.....But the Rear Cover Gasket which is the carrier for the rear main seal.
It requires a special tool to align/center the Rear Cover to the crankshaft.
$1,000 is a little rich for that job....Should include a Oil Pan Gasket & Pick-up Tube O-ring for that.
