87 Camry PS leak
South Carolina
I have posted this thread on the additive forum as well so pardon the duplication. I have searched all of these forums for info on leaking PS. I was looking for an additive to hopefully stop or at least slow the leak on an 87 Camry. It has gotten worse after I added 2-3 oz of ATF(Dex III) after I first noticed the level was low. Seems to have made the leak worse. Based on my search looks like Lucas is one of the quickest/easiest although not best fixes for the long run. Can't really afford a replace or rebuild until around June. Any other additive suggestions would be appreciated.
if it is leaking around the end seals (common), a bottle of Power Steering Stop Leak fixed both of my Camrys. Make sure you get the kind that is compatible with the fluid you use.
good luck.
The old timers I grew up with say to add brake fluid to it.
I never have,anyone else do that?
Some guys have all the luck, my pump blew apart 10 minutes after me noticing it was leaking. It sure made a mess of the driveway I was in!
Power steering isn't a big deal unless you do a lot of parallel parking in the city. I'm not going to fix mine.
Cheers, Steve
Cheers, Steve
well, it IS a big deal if your car uses the PS pump to power the radiator fan...(92-96 v6 Camry and 92+ Lexus ES300)
quote:
good luck.
What brand did you use (Lucas, STP, etc.) if you don't mind me asking? The 87 calls for Dexron II ATF.
I don't remember the brand, it was whatever O'Reilly's had on hand. I know there were at least 2 types, the differences being the type of PS fluid.
after a year, both reservoirs are still full so for me it's been a major success.
My Dad added some brake fluid to the auto transmission on my old Chevy Impala, this was at around 135,000 miles, we changed the fluid soon afterwards, I am now over 200,000 and the transmission is still working fine.
Now on the power steering, I would suggest trying one of the Dexron-based stop leak formulas, I have no specific experience so don't know which one is better or worse. Go with a brand you recognize.
A rebuilt rack is not *that* expensive or hard to install.
If your steering rack boots have been torn for some time (I guess they must be leaking or you wouldn't see the leaking PS fluid) probably the seals on each end of the rack are shot. Again it's not that hard to change the rack. You don't have to separate the tie rod ends, just unscrew them as if you were setting the toe-in. Work carefully and know what you are doing when working with steering, or find a shop that knows.
Avoid cranking the steering back and forth without moving the car, particularly when it's cold out. I know if you park on the street in in a Northern city this advice is not too practical, but even in that case try to move the car either forward or backward while you are turning the steering wheel.
