Lucas 85w-140 Gear Oil - 4 Gallons at Amazon
NY
https://www.amazon.com/Lucas-Oil-Products-10045-85w140/dp/B00B9GPEI2
Price is showing as $41.99 for four gallons of 85w-140.
Not sure if this is a decent product for what someone needs, but not a bad price for brand name gear oil if you need that weight. Not sure if its a price mistake or will just be a single gallon, but it appears that the price was previously $108 or so, and is now down to the $42.
Hope this helps someone...
Other sellers on Amazon are $100+. Price history from 2018 - present shows it has never gone below $100 when sold by Amazon. So there's a good chance this deal is legit.
I'm all for hope but 4 gallons is super random. Is any gear oil sold in a 4 gallon container?
Obviously 4 qts in a gallon but a gallon is also never listed as "4 quarts" -- it's just "one gallon"
Anyway I need 85W140 but deal is dead
4 gallons would be a case. If short you can send it back for a refund. And at this posting the ad is still up.
I rolled the dice and placed an order. Listing wise, it all adds up for package dimension and weight. Funny thing the listing does show the old packaging and Amazon does have another listing for the same quantity but with the new packaging labels and higher pricing.
  • Wow
Reactions: D60
Excellent price, good for your backhoe ,KW, but not for use in most pickups,cars.
85W-140 gear oil is a high-viscosity lubricant designed for use in differentials, manual transmissions, and other gear applications that require protection under high pressure and temperature. It provides excellent wear resistance and is suitable for heavy-duty vehicles and equipment.
petroleumservicecompany.com mobil.com
Showed up as advertised. Decent deal.
