Hi,
I would like to know if it's a good oil for my car. I have a 95 Jetta with a 2.0L 8v.
My mechanic sold this product ( I think it is Lubro-moly Vollsynthese 5W40) and he told me it's the best??
What to you think?? I need some info?
Thank you
quote:You can get Mobil 1 0w-40 at Autozone.
Originally posted by Turbo-Mazout: Thanks I will check how much my mechanic ask for a 5L jug. It's good that the Lubro-Moly is as good as the Mobil 1 0W-40 because I can't find this grade of Mobil 1 in my area. I can buy Delvac 1 but they only have 4L jug and I need 4.5L, so I have to buy 2 jug at 35 $can each.
quote:Just curious how much your mechanic charges you... My friend told me that the "purple" 5L jug costed him CAN$75.
quote:It is not logical for a 5W40 to have such low numbers. How many synthetics do you know with a flash point of 379.4 F ?? and this viscosity index i am sure it belongs to a mineral oil.. well....to a very bad mineral oil.. Actually the Aral's 5W40 that i am not sure whether is a PAO based or not has a viscosity index of 190...
Originally posted by Dr. T: OK...so what are the correct Viscosity Index and flash point numbers then? Enlighten us. Why do you state they are incorrect?
quote:i just got their e-mail(liqui moly), i believe i owe you an apology Dr. T ,you were right . It was a shock for me. Anyway here are the Aral's specifications: Applications: High-end high-performance motor oil with Aral Synthesis Technology with potential for extended oil-drain intervals. Helps to save fuel and to protect the environment. Large performance reserves even with maximum permissible oil-drain intervals and in engines with low oil consumption. Suitable for all four-stroke gasoline and Diesel (incl. direct injection and turbocharged) car engines. Required for Saab 9-3 Sport-Sedan diesel motor. Specification: ACEA A3 , B3 , B4 API SJ/CF Approval: Mercedes-Benz specification for service product sheet 229.3 BMW Approval Longlife-98 Porsche Approval VW-Norm 502 00 and 505 00 Issue 1/97 Opel GM-LL-B-025 Technical Data SAE-grade DIN 51511 5W-40 ASTM-Color DIN ISO 2049 2,5 Density at 15 °C g/ml DIN 51757 0,855 Viscosity 100 °C mm²/s DIN 51562 13,9 40 °C mm²/s DIN 51562 79 -25 °C mPa·s DIN 51377 3350 Viscosity Index DIN ISO 2909 190 Flash point COC °C DIN ISO 2592 225 Pour point °C DIN ISO 3016 - 36
