This is my first interval with a new oil after using Amsoil 5W-30 (SAE) since the 5,000 mile mark. It doesn't haven't any moly, but the #'s look pretty good.
From Dyson Analysis
Oil Brand/Weight : Lubro Moly 5w-40
Type Equipment : Passat Miles/Hours on oil : 4100
Total Miles/Hours : 25380
Oil/Air Filter: Mann oil filter/ITG foam air filter
Oil: Lubro Moly
Results ppm/% Comments (blank=normal)
Wear
Copper 1 low
Iron 2 low
Chromium 0 low
Lead 1 low
Aluminum 2 low
Silicon 14 no dirt, low wear #s confirm that.
Tin 0 low
Additives
Molybdenum 0 So much for the name ! , we read 0,not 3
Sodium 1
Magnesium 332
Zinc 964
Potassium 0
Phosphorus 767
Calcium 1650
Physical Properties
Water negative
Fuel negative
Antifreeze negative
Soot 68 colder weather, richer mixture, 34%
Oxidation 37 18.5 %
Nitration 111 55.5 %,better than last time
Sulfur 0 No sulfur in Rhode Island Fuels !
TBN 6 normal
Vis@100 C 12.4 barely into 30w, unlike Amsoil at 12.6
[ February 12, 2003, 03:39 PM: Message edited by: Patman ]
From Dyson Analysis
Oil: Lubro Moly
Wear
Copper 1 low
Iron 2 low
Chromium 0 low
Lead 1 low
Aluminum 2 low
Tin 0 low
Additives
Sodium 1
Magnesium 332
Zinc 964
Potassium 0
Phosphorus 767
Calcium 1650
Physical Properties
Water negative
Fuel negative
Antifreeze negative
Oxidation 37 18.5 %
TBN 6 normal
