Originally Posted By: millco
This is the only thing I have ever seen as far as a test ranking different fuel additives. This is why I quit using MMO in my rigs. If someone knows of a benefit or what it is supposed to do for an engine as an additive; then please post up.
Here is the 'Study' of Different Fuel Additives on Diesel Place
See number 17) for the results on MMO . . . .
HTH,
I found the study looking at how diesel lubrication was effected by various additives that Millco linked in the current MMO thread interesting. I was astonished to see MMO reported to have decreased lubricity. Since diesel, even ULSD, have inherent lubricative properties that exceed gasoline, I suspect MMO would increase lubricity in gasoline but is merely a guess.
From the article, I played a bit with the data. It shows that Opti-Lube Summer Blend provided the most lubricity value increase to diesel fuel for the least amount of additive. I thought others might find interest in the article and the spreadsheet play. I also wonder if any of these additives could be safely used in gasoline engines?
Doug
HTH,
Doug
