The boot of one of the CV joints of my Lancer has been torn next to the clamp that keeps it tight on the CV axle's shaft. I had noticed some staining on the inner fender's surface, but I hadn't paid much attention, since I thought it was something splashed from the road. I think that the staining is there about 1 to 2 months max. Today, I noticed some grease splashed on the bottom of the shock absorber and on the front lower arm and I confirmed that the boot has been torn.
I plan to get the boot replaced with an SKF universal boot that will get installed with a CV boot expander without removing the CV joint from the CV axle.
Since the boot has remained torn for some time and probably the grease has been contaminated I would like to ask 3 questions:
- How should the old grease get removed while the CV joint is fitted on the CV axle? Is wiping it and using brake cleaner an adequate method?
- How should the new grease put in place? Is it OK to be done with a gloved hand or are any special tools needed?
- I don't get any noises or any other symptoms from the CV joint in question. If it has been driven around with contaminated grease for some time, how likely is it to fail in the future, in the absence of any issues - as I said - with it currently?
