LUBER FINER PH-10064 CUT OPEN
In the shop
Another vehicle that my work purchased recently. 2019 Chevy equinox base model; 29,966 miles. I put four good tires(read:new Goodyear’s) and inspected it. Had this filter and unknown 0w20 oil. Put a Auto Extra (Purolator made) 10290 and some Safety Kleen 0w20 DEXOS oil in and on.
So no maintenance records other than the oil weight? That filter is probably okay for some chain lube shop. I bought a few e-core Luberfiner filters from RockAuto for my Jeep. I hope they are adequate…..,
Bought from a dealer down in Washington County PA. I’m no salesman; dealer may have records, vehicle coulda been private owner that wanted something different.
Looks like filter did OK
Unknown fci on this jobber tier filter, but it looks ok. Like it got the job done. It's like the 1st generation GM ACDelco ecore OFs with felt/fiber endcap and separate bypass. Now metal endcap like ST&ACD. And no combo valve here, a good thing.
Thanks for c&p.
I'd be curious to know if the ST12060 is like this or like the OEM with metal endcaps. I always just buy the OEM because the vehicle is a lease.
Haggler: I have a ST white can filter. Appears to be plastic cage too. I’ll cut and post it in lil’ bit 👍😊
Thank you sir, I actually was going to cut my recent kia oem filter but it was a mistake to buy an exhaust cutter since I dont have a vice. It was 93 degrees and i did the oci on the side walk due to this crappy apt. I just didnt have the hand strength or tools I have at my parents house. If im not such a cheap a ill buy an actual cutter.
Haggler: I promise in a bit I will cut the ST 12060. Just finished packing to head to Boiling Springs PA Saturday for turkey day/holiday
