Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 2,668
My power steering system (05 Scion / Toyota) has never been serviced and I don't recall ever topping off the fluid, it is a little lower than I recall but still works great. It is pretty black though and due for a service after 18 years and 180k miles.
Do you expect this to work? The LubeGard website states:
"Through constant use and high operating pressures, other types of wear materials are also generated that degrade the system. The result of this pressure and heat is fluid breakdown, contamination, loss of lubricating properties, and varnish deposits. When power steering fluid circulates throughout the system of pump and gear, it picks up wear material as well as contamination from the breakdown of aging hoses and seals."
Viscosity at 40° C 30-35 cSt
Viscosity at 100° C 5-8 cSt
Flashpoint (COC) >400°F
Pour Point 10°F
My plan is to flush the system with ATF until red fluid comes out and then add the flush, run the steering wheel back and forth a few times, then drain it to see if it actually removes varnish deposits or anything else not found in the regular flush. To show if there is any difference I will run the different catch bottles through a coffee filter as well to see what was picked up. I'll shoot the video and post the results later.
What do you think?
BENEFITS:
- Safely removes deposits and impurities
- Prepares system for new fluid
- Conditions and revitalizes seals and components
- Deters internal power steering fluid leakage from developing
- May postpone or eliminate the need to replace power steering componentshttp://lubegard.com/pdfs/LXEATFComparisonbrochure.pdf
- Cleans, conditions and prepares the entire system for replacement of worn components
Pour Point 10°F
What do you think?
