Lube for a Ford Transfer Case
The Garden State
I've got to agree with rgl about using a good synthetic or really good semi synthetic ATF(Schaeffers #204S
) for the transfer case. With the chain driven transfer case a gear oil is most likely to be too thick and cause problems. Change it every 30,000-50,000 miles, depending upon 4X4 usage and you should be fine. I looked at the manual for my 2002 F150 4X4 and they don't even mention changing the transfer case fluid ever
! Not a good idea if you want to keep the truck for long time. It's a cheap and easy maintenace to do. A lot cheaper than replacing the transfer case.
Whimsey
With 85K miles on my truck, I'm long overdue to change the transfer case fluid, even though 99% of those miles are highway use in 2 wheel drive.
The manual recommends ATF. Is there any other lubes that I should use to protect the planetary gears and chain drive. Would Redline MTL be a good alternative? Mix a Mobil 1 ATF with a synthetic gear lube? Your opinions and suggestion are appreciated. Thanks!
I have used synthetic Mobil 1 ATF in the past and in my present F150 I am using Amsoil synthetic ATF because I found some cheap. My 2 previous Fords have had the chain type transfer case. I put about 200k combined on them myself and the transfer cases never gave the slightest trouble or leak (they each had about 70K when I bought them so total miles were about 340K combined). All I did was use synthetic ATF and change the ATF about every 50K, fluid came out slightly dark red but no wear metal that I could see.
My experience so far is that pretty much everything else in the 4X4 drivetrain will fail before the transfer case, including shift motor, U-joints, auto hubs, wheel bearings, etc. I would be afraid to add any thicker lube because it may be too thick and may accelerate wear.
I've always just used whatever is going into my auto transmission in both my current 4x4's. The Jeep Cherokee requires Mercon/Dexron ATF for both the transmission and transfer case (and before anyone asks, no, it is not ATF+3, the Cherokee with the 4.0l uses an Aisin Warner transmission, not a Chrysler transmission, and thus requires Mercon/Dexron), and my '99 F150 calls for Mercon V in the transmission, and Mercon in the transfer case.
I've used Valvoline Durablend since it covers Mercon/Mercon V/Dexron and it has worked fine in everything I've used it in.
For reference, the maintenance schedule for my '99 F150 calls for a 60,000 mile interval on the transfer case fluid, regardless of severe duty or not.
