For cars that call for the Esso LT 71141, what fluids have you guys used that you have found is even a *better* ATF fluid with the ZF AT transmissions ?
I just did a pan drain/refill and stuck with the OEM fluid since the car is under warranty. However, I
d be curious to hear ither fluids and your experiance with them .
