Perhaps you could suggest to him to do a video concerning that data. I know I would be interested in what he has to say.He doesn't have it on hand to share.
Yes! I would take Donaldson data very seriously like I do with Ascent ISO testing. I would love to see the reasoning for completely opposite results.Perhaps you could suggest to him to do a video concerning that data. I know I would be interested in what he has to say.
Before that efficiency loss vs loading curve from Purolator/M+H ever came up on BITOG, I had email traffic with a Purolator engineer and he mentioned the "hockey stick" shaped efficiency curve when I asked about filter efficiency change with time. When first introduced the fact that oil filters lost efficiency with use, people wouldn't believe it because as Purolator said: "…test results for an oil filter media exhibiting a non-intuitive filtration behavior."Preface by saying, like much of the info LS Jr puts out, but I believe he's off base here on oil filters becoming more efficient with use. M&H conducted a study on oil filter efficiency which is the source of the oft posted filter efficiency graph diagrams (post #16 this thread).
Like others have said, I think there’s a good bit of interest in seeing this data. Would be much appreciated!
NaturallyI posted on the video, asking Lake about his claim that oil filters become more efficient, and that it is directly opposed to other test results. I also asked him about his practice of pouring a quart of oil in, to flush out debris. He replied "Stay tuned for the next two videos".
so he is like Ai you never exactly get a real logical straight answer.I posted on the video, asking Lake about his claim that oil filters become more efficient, and that it is directly opposed to other test results. I also asked him about his practice of pouring a quart of oil in, to flush out debris. He replied "Stay tuned for the next two videos".
Send him the link to the big Ascent ISO testing thread. See if he can explain why every filter in that test lost efficiency as they loaded up.I posted on the video, asking Lake about his claim that oil filters become more efficient, and that it is directly opposed to other test results. I also asked him about his practice of pouring a quart of oil in, to flush out debris. He replied "Stay tuned for the next two videos".
More like a salesman, wetting your appetite so you will come back for more.so he is like Ai you never exactly get a real logical straight answer.
Oil and air filter "caking".I've been texting him. He has data from Donaldson showing oil filters becoming more efficient with loading.
More like a pitchman.More like a salesman, wetting your appetite so you will come back for more.
If you consider this is from doing that cold - with only one quart in an eight quart system - no wonder the dipstick is pristine post change …FWIW I generally dump about a 1/2 quart of fresh oil in my stuff to drive out the oil from the bottom while draining. I get a breif surge of dark used oil then followed by clean coming out of the pan (as expected). Does it make a difference in the long run? Probably not, but it makes me feel better about it so thats all that matters![]()
In the Purolator/M+H graph shown in post 16, the efficiency goes back up as the filter "cakes" to the point where it essentially becomes totally clogged. That's the only time oil filter's get more efficiency with loading. And that's not a point where you want to let the filter get to, as it can make the bypass valve open way too easily and often. If oil filters got more efficient with loading, we would have seen it happen in the ISO 4548-12 tests that Ascent conducted. All 5 of the filters he tested all lost efficiency as they loaded up with debris. The test stopped when the dP was 8 PSI above the new fresh filter dP, so they were far from total caking. So an article like that one is misleading, making it sound like oil filters will become more efficient with use, but that's no actually the case.Oil and air filter "caking".
https://www.iqsdirectory.com/articles/liquid-filter.html
I'll use the "flush" method when I switch oils, but I no longer move fast enough to dump in a quart from above and get my butt under the car to see what it looks like coming out. I have a camera which I'll focus on the oil drain and shoot a short video, assuming I don't forget. If I actually see the darker oil coming out, then start getting the new oil, I'll post it to YT.FWIW I generally dump about a 1/2 quart of fresh oil in my stuff to drive out the oil from the bottom while draining. I get a breif surge of dark used oil then followed by clean coming out of the pan (as expected). Does it make a difference in the long run? Probably not, but it makes me feel better about it so thats all that matters![]()
I'm looking at the oil filter efficiency change from new to fully loaded, like seen in the Ascent ISO efficiency thread. Have you seen and read that thread? It shows that all the filters he tested lost efficiency as they loaded up. Similar to the graph on post 16. They lost efficiency at "mid life", and even lost more efficiency by the end of the test, defined by a dP of 8 PSI above the new debris free filter dP. None of them got more efficient over the debris loading period that caused 8 PSI above a clean filter.Yes, I know that. My thoughts were far from "full cake". But I think you are looking at it as far as end game. Donaldson and Lake's comment are looking at it mid life where the larger pores are blocked by larger debris, hence not changing out Lake's oil filter because it is HAS caught larger and smaller debris because it has some load.
Air filters and oil filters behave differently as they load up. This was mentioned earlier by a few other members, and the reason was given. Wonder if LSJr is also thinking oil filters behave like air filters as they load up? They don't behave the same. Ascent's ISO efficiency testing shows how oil filters behave with debris loading. Purolator/M+H says the same.Donaldson saying not to change out air filters too early as your filter is "filtering better" mid life.
The OG Ultra tested by Ascent also lost efficiency as it loaded up with debris. Go read that thread. It didn't lose as much efficiency as the less efficient filters. As mentioned before, oil filters that rate high efficiency in the ISO 4548-12 efficiency don't shed debris as bad as lower efficiency oil filters. The Boss and Wix XP in the Ascent ISO test lost efficiency like crazy as they loaded up. That's one reason their ISO efficiency is so bad.Just like on an old style Fram Ultra with the thicker full synthetic media I would sometimes go TWO 3,000miles runs on the filter and because the filter has 3D filtering with deeper embed the filter becomes more efficient mid life.
Air filters work on "cake" theory. The dP across an air filter is in inches of water. The dP across oil filters is around 5 to 15+ PSI. Oil filters don't start getting more efficient until they are almost totally choked down like the graph in post 16 shows. But it's a bad idea to run a filter to that level of debris loading unless you want lots of possible bypassing.Also I don't like cotton oil or dry air filters. So I install new thick 3D media OEM style filters every spring to get the maximum flow I can get while not using cotton filters. I throw away a perfectly ok filter every year. By the end of the year I bet I am stopping more debris then the first month I installed it. The media choice, thicker 3D media vs thin paper filter media. embed will eventually start caking where a cheap thin paper filter will start the caking process quicker. As we all know, for the most part. Also I have a cheap fiber blue pre filter in both mine and my daughters furnace and get and want the almost full thin caking of the pre filter to allow longer use of the MERV 13, 4 inch thick main filter. I double+ the time these filters last with this process.
Yeah, doing that falls in a "similar" realm to those that prefill their filters with an oil change. Likely doesn't make a significant difference, but one does it because they can and it makes them feel better about the start up rattle time with the oil change.FWIW I generally dump about a 1/2 quart of fresh oil in my stuff to drive out the oil from the bottom while draining. I get a breif surge of dark used oil then followed by clean coming out of the pan (as expected). Does it make a difference in the long run? Probably not, but it makes me feel better about it so thats all that matters![]()
