Thanks Tom for pointing this out. Red Line has told me on two occassions that their oil will not clean deposits, but run clean.
What's interesting to me is the Valvoline Patent for their Premium Blue Restore. That oil is designed to clean existing deposits and I believe is PAO/V (POE). Are there different POE's that can clean deposits? Valvoline Premium Blue but with a base oil composed of 62.5% POE, 25.0% PAO, and 12.5% AN. It's meant to be used for a single 5,000-mile OCI every 100,000 miles in HDEO engines to clean the piston-ring carbon deposits as maintenance to restore horsepower and fuel economy.
<div p-id="p-0001">A lubricant formulation which is effective to remove or prevent carbon deposits in internal combustion engines has a solvency as defined by aniline point from about 20 to about 115,
www.freepatentsonline.com
"The lubricant formulation can be formed from a blend of Group III, IV and V lubricants, in particularly polyalphaolefins,
alkylated naphthalenes and polar Group V base stocks such as polyol esters.
The carbon deposits can be removed from the engine piston by simply running the engine with the lubricant for one required cycle, or can be used continuously in the engine to prevent buildup."
