This is your error. They didn't need to present data from an RPM sweep cold vs the same sweep hot.
They had a 1700 rpm data point, cold, AND a 1700 rpm data point, hot. Two data points that were compared.
I don't think you've really watched the video very closely, or don't correctly recall what you saw. There is no place in the video where they show the filter dP with hot oil at 1700 RPM ... if you think so, at what time in the video are you seeing that.
If you watch the real time data on the "screen 7" around time 8:00 after a hot pull and they bring the engine back down to 2900-3000 RPM (the lowest hot RPM ever shown),
the filter dP is 4.3-4.4 PSI, and the oil temp is 248-250F. The data is never shown there or anywhere else in the video at 1700 RPM with fully hot oil.
The bottom line is that it was an incomplete test without at least doing a RPM sweep with the "cold" room temperature oil.
It doesn't have to be performed at constant pressure unless you're trying to make isobaric conclusions from the flow data, which you did/have/are. The pressure data doesn't need to be isoflow unless you're trying to make isoflow conclusions from the data, which you did/have/are.
The Melling graphs of pressure and flow vs RPM that I posted earlier clearly shows that those pumps have enough swept volume to start putting it in pressure relief (depending on what pressure relief valve spring it has) around 2700-3200 RPM with 200F hot 5W-30 oil.
BTW, that isoflow graph you posted earlier shows that for a fluid with a dynamic viscosity of 100 Centipoise or more, the pump slip correction doesn't even apply. The main isoflow lines on that graph are for fluid viscosity of only 1.0 cP (they call it CPS - same viscosity unit). So when the LSJr video shows there was 80 PSI with the room temperature oil at 1700 RPM, then the pump very well could have been somewhat into relief, depending on the pump on that engine which could be higher volume than a stock pump. If it was in relief at all, then any "pump slip" is out the window and zero effect. If it's not in pressure relief at all, then there isn't enough pump slip to make any difference. Since the oil is "cold" (room temperature) the oil is thicker than at 250F, and therefore any pump slip would be less than after the oil has reached 250F.
You and I both have the same objection - when a specific test case is used to support absolute statements. We know LSJ came from a race car world, dry sump systems with tank heaters. Cold function probably doesn't matter much to him. My experience with an LS engine was a 250k mile 5.3 in a GMT800. It spent plenty of time under 1500 rpm, making torque, and was probably a bit looser than it was (oil pump and engine clearances) from the factory. If I was an intern designing an LS engine for that application I'd probably oversize the oil pump to give sufficient hot pressure at low RPM. I have never questioned that a degree of filter bypass could occur under some conditions. Again, those conditions don't sound like my drive cycle. We can always setup an experiment to make a thing happen. I have never argued that filter bypass or pump bypass does not happen.
If you read the threads about the on-vehicle filter bypass testing done by Jim Allen, you would see how possible it is to make oil filters go into bypass given enough engine RPM with cold thick oil. As I've always said, keep the engine RPM down until the oil warms up pretty good to keep the filter out of bypass.
If the LSJr test would have done a full RPM run with the oil at room temperature, I'd bet that filter would have hit bypass dP. The oil pump would have been in pressure relief, but as the Melling pump graph shows the pressure and flow volume would still increase with RPM and therefore the filter dP would also keep increasing with higher RPM.
I have questioned your very absolute/simplistic statements that PD pumps are constant flow - where output is rigidly proportionate to RPM, regardless of factors like viscosity and back pressure on the pump...aka the factors that drive pump slip. (This is generally the statement you make when someone questions if a more restrictive filter element would impact flow.)
I've talked about pump slip way before you ever popped in randomly in past threads and this one to try and discount my views. But just like now, I'm still saying it's a factor that really doesn't matter unless the pump is very worn out and the slip is excessive. And pump slip is really only going to show up more when the oil if very hot and thin, like at hot idle. It's totally out of the picture when the pump is in pressure relief.
When guys come here and claim that "Filter X" made the oil pressure do way down at an idle, then that could be a case of a worn out oil pump being sensitive to a change in filter flow restriction because the pump is worn out. Most of those cases are vehicles with tons of miles on them. I've also made it clear that the flow will basically remain the same vs RPM if the pump is not in pressure relief. If the pump is in relief, the output volume and pressure can still increases with more RPM on a simple spring loaded PRV as seen in the Mellilng graphs. I've made many statements over the years with qualifiers, but you seem to have latched on to thinking I just blurt out some "absolute/simplistic" statements, which isn't true as if that was the case we wouldn't be this far into the "technical bickering" about PD oil pumps, lol.
Then as you have acknowledged pump slip, I have also questioned the absolute/simplistic statement that it's 15%, which oversimplifies the behavior and cannot be determined from the data presented.
The Melling pump graph posted earlier, when uses along with the known swept volume per revolution of that pump, shows that pump has ~15% pump slip, and that's with 5W-30 at 200F. If the oil was at room temperature the pump slip would be less of course. I highly doubt healthy gerotor PD oil pumps on engines are sporting pump slip much worse than 15% with hot oil ... maybe 20% max. The are certainly not 30%, 40%+ unless worn out or total junk off the factory floor or the oil is 0W-8 at 300 F.
And both of these ignore that we live in a world with variable displacement oil pumps running around on the street.
Variable PD oil pumps, and the various spring and/or ECU type controls used on them is a whole world in itself, and makes discussions like this even more complicated.
