Man, lots of nugs for me this morning hahaha guess I'm not hanging out/spending time researching in the oil filter sub enough!watched it - usually a nugget or two in his video’s … Not much here.
But now there's "bickering" in this thread about what words aren't allowed on BITOG, not even related to bickering about technical discussions, lol.I had no idea how that all worked and it was easier to watch this than read 100's of posts of bickering here to get to the same info.
I posted some links above.Where is the Allen study? Btw I heard no bad words in this video, maybe missed it. I don’t think they did this right.
Exactly, if he doesn't comprehend that then one has to wonder what he really does.ADBV on a base up vertical orientated filter will keep the oil in the galleries above tghe filter from draining down back through the filter.
Yes, that's been a long on-going misconception that an ADBV doesn't matter if the filter is mounted base up and vertical.Exactly, if he doesn't comprehend that then one has to wonder what he really does.
It just showed that if the oil is warm enough on an engine with a pretty low volume oil pump that the dP across the filter won't be enough to cause it to bypass. Do that same max RPM dyno pull with the oil at 20F and it would go into bypass for sure. They don't really touch on that much, and leave the audience thinking (and ready to go start spreading misinformation, lol) that oil filters never go into bypass unless they are nearly totally clogged ... which isn't a true statement. If the oil is cold enough, the bypass valve setting low enough and the engine RPM high enough the filter will bypass.So this video is full of fake news? ADBV and bypass events?
Even if they would have done the dyno run to redline with room temperature oil (which they didn't do) the filter would probably have hit bypass dP.I would also have liked to see cold weather testing. I don't know where this dyno facility is located, but most of the country is in the middle of cold weather. I wonder if they could leave an exterior door to the dyno chamber open overnight, and then rerun this test early in the morning?
You must account for the outlet restriction presented by the engine. I didn't look at the rig or the video but the ΔP would of course be the mains drill feed pressure minus the oil pump outlet pressure. There could be an empty can on the filter boss or a can loaded with a media cartridge, or media cartridge with bypass poppet combination. Or simply a length of tubing smaller than the outlet but larger than the mains drill feed....
He said as the oil was warming up the dP across the filter was increasing (ref time 8:48). I say no way on that one - something is off there. If the oil becomes thinner and the flow rate stays the same through the filter, then the dP across the media will be lower - there is no physical way it would be higher. What's going on inside the engine after the filter has no bearing on the dP across the filter. The dP across the filter is solely a function of the oil viscosity and flow rate through the media.
You should probably watch the video before trying to talk about the video.You must account for the outlet restriction presented by the engine. I didn't look at the rig or the video but the ΔP would of course be the mains drill feed pressure minus the oil pump outlet pressure. There could be an empty can on the filter boss or a can loaded with a media cartridge, or media cartridge with bypass poppet combination. Or simply a length of tubing smaller than the outlet but larger than the mains drill feed.
The PD oil pump like used on the GM LS will still increase volume output and therefore pressure even after the spring loaded bypass valve starts opening. In fact, that pump will start going into pressure relief well before redline, but the flow to the engine and hence the pressure will still increase at a lower rate as RPM increases.I mention pressure and not volume flow, as the filter will be presented with a constant pressure at the filter inlet as rpm rise, since the oil pump should be now operating in bypass at mid/high rpm. If the "protection" of the oil pump bypass becomes compromised (no bypass) and flow is increasing with engine RPM, the ΔP approaches the burst pressure of the filter can/gasket design limit and you will either blow open the filter can crimp or, more often, blow out the base gasket and dump oil all over the track. If outlet drill size and flow was unencumbered or non critical, this would not occur.
Yes, for the overall oiling system ... but again, what's going on just across the oil can be looked at regardless of how the overall oiling system reacts to the restriction of the oiling system as a whole. They were trying to use the engine as an "oil filter dP vs flow test rig" without full instrumentation.Taking the setup and the calculus to limits: Fully Restricted outlet = No volume flow = No delta; an Unrestricted outlet = max flow = Max delta - as the intermediate restriction presents itself fully.
As covered above, the flow is not unrestricted when the pump is on an engine. The OEM LS oil pump only puts out around 7-8 GPM at redline. They didn't say what pump was on the engine (stock or aftermarket), but even an aftermarket pump like an aftermarket Melling doesn't put out much more than 10-12 GPM when on the engine depending on what pressure relief spring is used in the pump.Again, I did not watch the video yet and I am blind to engine rpm and their pump bypass setting. So I can't question why one would ignore or dismiss the actual test gauge reading " ... as something is off there". I don't even know the engine used in this video, but an unrestricted SBC factory pump is typ 15gal/min at mid operational rpm. Another consideration, Multi Vis motor oil exhibits Non-Newtonian fluid properties, but I would largely ignore that on this simple exercise. - Arco
I went back and rewatched the video today and found that claim to be odd. Fwiw, didn't make sense to me. It seems to go against what you have always said about the oiling system itself being ~15x more restrictive than the oil filter. Am I correct in that?....When they claimed the dP across the oil filter was increasing as the oil warmed up (ref time 8:48), there's no way that could physically happen unless something else was going on with the test setup that they didn't understand or didn't divulge that cold cause that to happen.....
Yes, the oiling system after the oil filter is around 15 times more flow restrictive because of journal bearings and other tight flow clearances throughout the system. That's why an oil filter may only be showing 5 PSI of dP when the oil pressure going into the engine is showing 75 PSI. 75/5 = 15 times more pressure is caused by the engine vs the oil filter.I went back and rewatched the video today and found that claim to be odd. Fwiw, didn't make sense to me. It seems to go against what you have always said about the oiling system itself being ~15x more restrictive than the oil filter. Am I correct in that?
There is a good explanation for why the dP across the oil filter might increase as viscosity is reduced. The dP would decrease if the flow rate were kept constant, but the flow rate will increase as the viscosity decreases, as long as the oil pump is in pressure relief.When they claimed the dP across the oil filter was increasing as the oil warmed up (ref time 8:48), there's no way that could physically happen unless something else was going on with the test setup that they didn't understand or didn't divulge that cold cause that to happen. When someone can prove that the dP across an oil filter increases as the oil gets hotter with all other factors held constant in a good lab dP vs flow setup, then we can re-write the fluid dynamics books, lol.
Why not put these questions as comments on the YT video to see what they say?You should probably watch the video before trying to talk about the video.![]()
Like said, what's going on after the oil filter does not effect what's going on across the filter. You could mount that filter on a test rig in a laboratory and conduct a dP vs flow test. It's done all the time per the ISO 4548 test. Look at Ascent's dP vs flow and even BR on YT dP vs flow tests. In this case, the engine was the test rig. They simply had a pressure gauge before and after the oil filter. They didn't measure oil viscosity, but simply said the oil was either cold or hot. You can see on the data screen it was around 100C when hot. "Cold" was whatever room temperature was in the dyno room .. so call it 65-70F. So if the two pressure sensors they used were located in big oil galleries before and after the filter, then for all practical purposes they were measuring the dP across the filter.
