LSJr digs into what a basic lubricity tester was created for & where it excel & does not excel by testing motor oil and gear oil. Shows that It only measures a certain type of wear & calls out a "famous" Youtoober using it to "test" oil. It does not correlate or give the whole picture of actual wear dynamics inside an engine. There is no API testing standard that uses these types of tools for motor oil. Oil manufacturers etc spend millions of dollars to test oil & this cheap tool does not suffice.
LSJr uses Castrol API SJ Classic 20w-50, Castrol API SP 20w-50, GL-5 Valvoline, & a High Performance Lubricants gear oil (Specially made for his dad's race car) on a lubricity tester. Put the same oils on a test using the TE77 Recipricating Rig. Where the gear lube did well was on the lubricity tester but the same can't be said on the Recipricating rig that shows the motor oil & the Castrol API SP having lower wear (vs the Classic SJ).
So in short, Don't rely on these lubricity testers to show which oil performs "best" in your engine. There are different forces going on in an engine that a lubricity tester can't & does not show.
